Old 07-14-2013, 06:27 PM   #1
Goth Popper
99 Boxcutter's Avatar
The hinge on my center glovebox console lid is broken:
The hinge is broken off. Can it be fixed of do you have to replace the whole assembly?
www.appleneworleans.com
99 Boxcutter is offline   Reply With Quote
Old 07-14-2013, 07:30 PM   #2
still plays with cars...
BoxsterSteve's Avatar
This is a super easy fix. Got my repair kit from Sunset parts. No instructions included, but not really needed. I Googled for Oddment tray cover repair. Porsche put out a pdf file outlining the repair steps.
The whole job took me under 30 minutes, including cleaning up afterward and reassembly.
No, you don't need to remove the console from the car, just the carpeting from the rear bulkhead to insert the backing brackets for the rivets to grab into.
The new hinge itself is the drilling template. You'll need a 4mm drill bit. Got mine at Lowe's. Drill 2 holes, pop rivet the hinge to the console. There are even tabs there to keep everything perfectly lined up.
Disassemble your console lid to pull the hinge pin and attach it to the hinge you just riveted to the console. Re-attach the armrest cover and you're done.
Six speed 2000 Boxster S
Old 07-14-2013, 09:05 PM   #3
You need to quit breaking stuff
Old 07-15-2013, 01:15 AM   #4
bar10dah's Avatar
Pelican
Suncoast
Or call Sunset
They're all within a few bucks of each other. All three are good resources for parts.
bar10dah is offline   Reply With Quote
Old 07-15-2013, 12:59 PM   #5
I must be overtired... can't stop laughing.
Old 07-15-2013, 01:08 PM   #6
Send a message via Skype™ to Gregtenerife
One here on Ebay.
New Genuine Porsche 911 - 996 and BOXSTER (986) Centre Console Hinge Repair Kit | eBay
Gregtenerife is offline   Reply With Quote
Old 07-15-2013, 05:25 PM   #7
Had you done a search you would have found this thread, complete with pictures, instructions, and the part number:
http://986forum.com/forums/general-discussions/35637-broken-oddments-tray-hinge.html
or this thread, again with detailed info:
http://986forum.com/forums/general-discussions/11101-center-console-hinged-lid.html
and a few more also covering the same topic.
'99 black 986
