Old 07-14-2013, 04:15 PM   #1
Brake fluid light on
Brake fluid light is on but fluid level fine. Brake fluid fine. Recently flushed no air. Suspect stuck sensor. Any suggestions. Brake work fine ABS failure also on.
opus69 is offline   Reply With Quote
Old 07-14-2013, 04:42 PM   #2
heliguy's Avatar
Add fluid till the light goes out.
Old 07-14-2013, 05:10 PM   #3
Fluid is not the problem. Tank is full and system has been bled. No air. It is a sensor issue.
Old 07-14-2013, 05:53 PM   #4
Track rat
Topless's Avatar
The light is a "brakes need service" light so check pads and fluid. A worn or grounded pad wear sensor will also trip the light.
Old 07-14-2013, 08:11 PM   #5
Brakes, pads and rotors very new and were working fine until car sat for several months and the battery went dead. Now abs has a 4270 code and brake fluid light on even after bleeding again.
Old 07-14-2013, 08:41 PM   #6
aclark133's Avatar
Check the sensors.. if they werent replaced with the pads. Also, my car has the on-board computer which has a separate warning for low brake fluid.... ask me how i know
aclark133 is offline   Reply With Quote
