Old 07-05-2013, 07:37 PM   #1
evo-r's Avatar
Thumbs up @@ cob led drl @@
Just retrofitted some COB (Chip On Board) LED strips into some LED housing/lens… again… all from eBay…
I choose this LED housing/lens for a more refined finish; removed the original LED board and installed the COB strip.
Under the sun at noon time
Night shots
Found this clip of a Skyline with COB on YouTube
Super Bright COB White LED Lights for DRL Fog Driving Lamp - YouTube
His: 2003 Boxster & 2008 MDX
Hers: 2011 Golf TDI
evo-r is offline   Reply With Quote
Old 07-05-2013, 07:38 PM   #2
evo-r's Avatar
Each COB strip contains 60 tiny LEDs so when it lighted up it looks like a light bar instead of individual LED and it is much brighter than the typical LED.
Hers: 2011 Golf TDI
Old 11-05-2013, 10:53 AM   #3
Can you provide exact measurements for the COB LED? Overall and lighted surface? That would be great
Working on an integrated-into-headlight DRL/parking light retrofit for my next projector install...
Old 11-05-2013, 03:23 PM   #4
edc
550 Anniversary
edc's Avatar
Good effort. To 'clean up' the look at the front of your car you might consider an amberectomy to remove the orange reflector in the headlight unit.
Old 11-05-2013, 08:21 PM   #5
evo-r's Avatar
The dimensions are in one of the listing pictures; http://bit.ly/1b70icp
Hers: 2011 Golf TDI
Old 11-05-2013, 08:22 PM   #6
evo-r's Avatar
Thanks, will probably do that in 2014.
Hers: 2011 Golf TDI
Old 11-06-2013, 04:56 AM   #7
heliguy's Avatar
And an amber-tag-ectomy!
Old 09-26-2014, 07:25 AM   #8
Coaster's Avatar
Any issues/concerns with cooling having them in the vents? How are they holding up vs road trash?
Coaster is offline   Reply With Quote
Old 09-26-2014, 09:32 AM   #9
evo-r's Avatar
No noticeable affect on the front cooling, gauge always stay around “8”. The LEDs are as good as day 1 and the plastic lenses are holding up very well against road debris, but I only drive on nice weather days and not exposed to road salts/sands during winter time.
Hers: 2011 Golf TDI
Old 09-26-2014, 10:47 AM   #10
I am my own mechanic....
Timco's Avatar
Can they be made a little less bright? As I see them on newer P cars, you can see the dots of each light and they don't really light the road. Just a visual thing. Or maybe half as many lights?
Those can easily be made the turn signals.
'08 VW Touareg T-3 wife's car
Old 09-30-2014, 09:58 AM   #11
evo-r's Avatar
I'm not an electrical engineer but I'm sure you can make them dimmer by adding some resistors, maybe? Yes, these can be turn signal lights if you wired them as such.
Hers: 2011 Golf TDI
