Old 05-10-2013, 05:52 AM   #1
Keeping the mesh windblockers on
Seems that so many 986 owners have only one mesh windlocker or none and are looking for same from time to time. I know they come with tabs and rubber thingees but is there any way people have devised to keep these from blowing off or coming loose?
Stephan Silverman is offline   Reply With Quote
Old 05-10-2013, 05:56 AM   #2
Zipties worked for me.
Old 05-10-2013, 06:03 AM   #3
Opposed to Subie Burble
Overdrive's Avatar
It's not pretty, but zip ties held mine in with no issues, and weren't noticeable unless I pointed them out to people. They still rattled because they sit in there more loosely than they should, but they went nowhere until I cut the ties and pulled them out myself. Just make sure you get some that are thin enough to fit through one of the holes of the diffuser, while still being long enough to wrap around the roll bar.
If you search a bit you'll find some things folks have done, mostly just explained. I've never really seen photos of the handiwork, but from the explanations it's pretty easy to imagine and figure out. Some people glue/double-sided-tape in a little strip of felt or rubber on each tab, and that provides a little more thickness to the tabs to quiet the rattles and squeaks, as well as provides some friction to keep them in place.
There are also some aftermarket options that are more like a larger version of the lexan middle wind deflector, which run the entire distance from one roll bar end to the other, and screw in place onto the roll bar itself to keep it in place. It's one of the products advertised in a few spots throughout this forum.
-O/D
IMSR + RMS
Robbins glass window top
Old 05-10-2013, 06:19 AM   #4
jaykay's Avatar
I used bicycle inner tube patch material on each tab. I cut the rubber to size an d built up a pad on each tab such that it was thicker and gad more grip.
986 00S
Old 05-10-2013, 06:34 AM   #5
Overdrive's Avatar
^^ See what I mean? Nice, jaykay. I think I'm going to try that when I go to put them back in.
-O/D
IMSR + RMS
Old 05-10-2013, 07:02 AM   #6
ccstud17's Avatar
black silicon on the tabs for me!
Stop lights timed for 30 MPH, are also timed for 60 and 90 MPH!
ccstud17 is offline   Reply With Quote
Old 05-10-2013, 07:41 AM   #7
I use the soft side of some black velcro tabs. Unseen and keeps the darn things from making noise or moving.
john90290 is offline   Reply With Quote
Old 05-10-2013, 07:59 AM   #8
I just added a small piece of thick black foam tape to each pad. snugs them up, stops any rattle and you can still pop them in and out to clean.
58ceramicgreen is offline   Reply With Quote
Old 05-10-2013, 08:02 AM   #9
BruceH's Avatar
Zip Ties
2001 Boxster S Lapis Blue
iPad Mini Dash Install
DEPO Tail Lights
Old 05-10-2013, 01:33 PM   #10
AKnowles's Avatar
One of my tabs is broken and the PO used a piece of Velcro on it.
Old 05-10-2013, 03:09 PM   #11
Porsche Pete's Avatar
Do what i do and wear a hair net... and if its really windy just zip tie it to your ears...(make holes with a bradawl)
2001 Boxster`S` Artic Silver
Porsche Pete is offline   Reply With Quote
Old 05-10-2013, 04:39 PM   #12
Newb
V-Rod's Avatar
I just purchased a pair and I noticed that they went in and out fairly easy. So I cut six pieces of 3M double faced foam adhesive and put it on all the tabs. Then removed the backing and carefully put the bottom in first and then the top while holding the tab until the screen was seated and then pressed the tab to adhere it. Oh I also put a strip of foam in the center recess in order for the whole unit to fit more snug. I did not remove the backing from the center piece. It is very snug with no squeaks or rattles.
1999 Boxster Ocean Blue Metallic/Savannah Beige
2001 Harley Davidson Road King w/Ultra Kit Black/Chrome
2004 Jaguar XJ8 Seafrost Metallic Green/Sand
2008 Land Rover LR3 Alaska White/Alpaca
2012 Honda Odyssey Touring Dk Grey/Lt Grey
V-Rod is offline   Reply With Quote
Old 05-10-2013, 04:46 PM   #13
Honestly, I ditched the windscreen thingys a long time ago, esp since I put the BK roll bar extension on a long time ago.
02 Boxster (DD sans kids)
08 Corvette Z06 (Track car)
Old 05-10-2013, 05:30 PM   #14
Zip ties work great. I use Panduit PLT3I-C0
Bryan topping is offline   Reply With Quote
Old 05-10-2013, 09:46 PM   #15
nieuwhzn's Avatar
Black zipties at the bottom, just to be sure.
nieuwhzn is offline   Reply With Quote
Old 05-11-2013, 03:12 AM   #16
Vista glass
Vista glass's Avatar
I used velcro cut to fit on the screen frame and the roll bar. It is invisible since all componets are black. They do make velcro in an assortment of colors and lengths, widths, check at a fabric retailer. Mine have no rattle. They are very secure, almost difficult to remove from the rollbar. There was one tab broken off when I got the car. They have been speed tested to triple digits without any movement.
Vista glass is offline   Reply With Quote
Old 05-11-2013, 06:56 AM   #17
The good thing about zip ties is that they make it just that much harder for the casual thief to rip them out of your car. Apparently this is not an infrequent occurrance.
Old 05-11-2013, 07:43 AM   #18
Overdrive's Avatar
This is true, and sadly, some folks will take the opportunity to pop those things out and run just because the opportunity was there. That said, the only time the top is down in my car is when I'm driving it. Remove the opportunity, and they can't take it.
-O/D
IMSR + RMS
Old 05-13-2013, 04:28 AM   #19
The problem with zip ties is that you need to remove the screens in order to clean the inside of the rear window. Velcro may not deter thieves (although the motion sensor in the optional alarm system will); otherwise, as has been suggested, just put the top up when parking the car out of eyesight.
southernstar is offline   Reply With Quote
