Old 04-23-2017, 07:32 AM   #481
Chuck W.'s Avatar
Originally Posted by Chuck W. View Post
Reminder .. Reminder.. & it is a great cause!
1995 Porsche C4 Cab
Old 04-23-2017, 08:47 AM   #482
Silver_Slug's Avatar
Originally Posted by Heiko View Post
The Magic ball says 5192 it is... LOL
H
Thank you Heiko! Worked like a charm. I can once again annoy my wife with my loud classic rock n roll....
Also, kudos to combining your love for cycling, and a great cause of battling cancer in children.
Cycling has been a huge part of my life as well, although recent nerve damage has limited my abilities. Thought I'd share a video I put together of our last trip to St George Utah. Click in if you have a few minutes to kill. Again, thanks for all you do for the forum... and the world we live in.
Regards,
Steve
Silver_Slug is offline   Reply With Quote
Old 04-23-2017, 11:08 AM   #483
Could I get some radio help as well. Type 4462 ser. W5009183 thanks it is much appreciated
Sent from my SM-G920V using Tapatalk
02 Red S. 4th owner 198k miles , now 225k miles and still going strong.
rczap is offline   Reply With Quote
Old 04-23-2017, 06:51 PM   #484
Heiko's Avatar
Try 9947 first and if that doesn't work try 9945
Cheers
Heiko
https://greatcyclechallenge.ca/Riders/HeikoVoss
Previously owned:
Old 04-26-2017, 08:54 AM   #485
Cheers
Heiko
Heiko, thanks for the help but neither code worked. Is there some other information that may help you find the correct one?
Rich
Old 04-26-2017, 09:08 AM   #486
Heiko's Avatar
Rich
Rich
Using the serial you provided 'W5009183' the codes are 9947 or 9945 so can you double check your serial number using the menu on the radio.
Turn off radio.
Hold down the TP button for at least 10 seconds.
Turn the radio on. "Becker 1" will be displayed.
Rotate the right knob slowly, as it will display the Becker model number.
Rotate again and radio serial number will display on radio display.
If the serial number is still the same as what you typed then something else must be wrong...
Heiko
Previously owned:
Old 04-26-2017, 09:39 AM   #487
Heiko here is a picture of the radio with the serial number shown. Not sure what else I can do.
Old 04-26-2017, 05:28 PM   #488
Hello Heiko,
Can you please provide me with the code for my radio?
CDR-220
Model: BE 6625
S/N: 15007745
Manufacture date: 42/07
Joe
jrgill is offline   Reply With Quote
Old 04-26-2017, 06:20 PM   #489
cdr 220
type 4362
ser x5020045
986patrick is offline   Reply With Quote
Old 04-26-2017, 06:32 PM   #490
Heiko's Avatar
Man there has to be something wrong with this thing...
The two codes I gave you are the two codes i get, I just ran them again for that serial just to be sure and 9947, 9945 are it.
Now I have seen the serial number display in error if the display is damaged. So for instance if the 5 was a 6 or the 9 was an 8 etc...
you can try 9643 as a third alternate but chances are slim that it will work. If you happen to question the display the only other option is to pull the unit out and read the etched serial on the side of it. I'm not sure what else to tell you....
Heiko
Previously owned:
Old 04-26-2017, 06:34 PM   #491
Heiko's Avatar
Originally Posted by jrgill View Post
Hello Heiko,
CDR-220
Model: BE 6625
S/N: 15007745
Joe
4623 should work fine for your radio
Heiko
Previously owned:
Old 04-26-2017, 06:35 PM   #492
Heiko's Avatar
Originally Posted by 986patrick View Post
cdr 220
type 4362
ser x5020045
0360 should work for yours
Heiko
Previously owned:
Old 04-26-2017, 06:39 PM   #493
Thank you Heiko!
Old 04-26-2017, 06:42 PM   #494
Heiko
Awesome!
Old 04-26-2017, 08:23 PM   #495
Heiko
If the info I have is right, would the dealer be able to help? Again thanks for trying.
Old 04-27-2017, 05:22 AM   #496
Heiko's Avatar
You can try the dealer - I haven't seen this process fail yet unless there are issues with the head unit itself, but I guess there is a first time for everything. If you do get a code that works let me know, I'd be curious to see what code ends up working for that unit and if the serial is indeed the one displayed.
Sorry I cant be of more help at this point.
Heiko
Previously owned:
Old 05-03-2017, 01:40 PM   #497
Radio code please
Would appreciate your assistance with this radio code
CDR220
Becker 1
Type 4462
Serial number 25014197
Thanks in advance
Xcellr8 is offline   Reply With Quote
Old 05-06-2017, 04:46 PM   #498
Heiko's Avatar
CDR220
Becker 1
Type 4462
Thanks in advance
4904 is your code Joe
Let me know if you have isuses
Heiko
Previously owned:
Old 05-09-2017, 07:18 AM   #499
Hello,
I also need help with the code for my Becker.
Type: CDR220
Model No.: BE 6625
Serial No.:15006390
Your help is much appreciated.
-K
kdbroad is offline   Reply With Quote
Old 05-09-2017, 07:29 AM   #500
Heiko's Avatar
Originally Posted by kdbroad View Post
Hello,
Type: CDR220
Model No.: BE 6625
Serial No.:15006390
-K
I will get back to you with a code tonight when I get home.
Cheers
H
Previously owned:
