Old 04-22-2015, 04:29 PM   #101
Heiko's Avatar
Originally Posted by BobSC View Post
Have a 1999 Boxster. Had to replace the battery. Need the unlock code for the CDR220 radio. Serial number is X5017740. Thanks!
BobSC - 1109 should work for you :-)
Cheers
H
Previously owned:
Old 05-06-2015, 10:07 PM   #102
Hey thank God! Finally might be able to listen to the radio! OK......, Becker model number is be2182 and the serial # is w5010248. a new member to the forum and would greatly appreciate if someone could help me out between that code thank you keep up the great work!
michaels1law is offline   Reply With Quote
Old 05-06-2015, 10:09 PM   #103
michaels1law is online now Report Post
Old 05-07-2015, 03:55 AM   #104
Heiko's Avatar
You can try 2737 - but I haven't had much luck with the old cassette units.
H
Previously owned:
Old 05-07-2015, 07:23 AM   #105
Rburro2
rburro2's Avatar
I just bought a 2000 Boxster. The stereo is working presently, but being the 4th owner I do not have the owners manual or stereo manual. Is there a way to find or reset the code before I have an issue and need to remove it to get the SN?
Last edited by rburro2; 05-07-2015 at 08:55 AM. Reason: Got answer under another topic
rburro2 is offline   Reply With Quote
Old 05-07-2015, 09:39 AM   #106
Rburro2
rburro2's Avatar
Type: 4462
CDP: 2081
SN: Y5038252
2000 Boxster 2.7- First Porsche Owned
Old 05-07-2015, 10:50 AM   #107
Heiko's Avatar
RBURRO2 - 1504 should be the code for your radio.
Always handy to have it before hand
Previously owned:
Old 05-07-2015, 01:33 PM   #108
Rburro2
rburro2's Avatar
Thank you..Heiko
Old 05-10-2015, 05:18 PM   #109
Cdr220
Type 4462
Serial 15064634
JaySea20 is offline   Reply With Quote
Old 05-10-2015, 05:34 PM   #110
Heiko's Avatar
Originally Posted by JaySea20 View Post
Cdr220
Type 4462
Serial 15064634
0721 is your code
Previously owned:
Old 05-21-2015, 07:23 AM   #111
Lost radio code 2002 Porsche boxster
2nd owner with no code. Battery died and need code
CDR220
Model BE4462
Serial number 15003543
Mceddy0815 is offline   Reply With Quote
Old 05-21-2015, 09:12 AM   #112
Heiko's Avatar
CDR220
Model BE4462
9864 and you should be good to go!
Previously owned:
Old 05-23-2015, 10:21 AM   #113
Need code
220
4462
Y5043640
Thank you in advance.
Ryan
McAlister91 is offline   Reply With Quote
Old 05-24-2015, 09:30 PM   #114
Help please
Fixed horn lost radio.
CDR-220
Type 4462
Ser X5026924
I follow a youtube video on how to fix sensitive horn that hunks with pot holes and hard braking. Steps included disconnecting battery and I can tell you this step was not needed and caused radio reset thus need for code.
Also the steps included adding O-rings on the top of metal bracket but indeed they should be placed behind it to put some distance between bracket and metal connectors that activate horn.
nejatali is offline   Reply With Quote
Old 05-25-2015, 04:22 AM   #115
Heiko's Avatar
Originally Posted by McAlister91 View Post
220
4462
Y5043640
Ryan
0465 for your radio
Heiko
Previously owned:
Old 05-25-2015, 04:24 AM   #116
Heiko's Avatar
CDR-220
Type 4462
Ser X5026924
7098 for your radio
Heiko
Previously owned:
Old 05-25-2015, 10:01 AM   #117
7098 for your radio
Heiko
Many thanks.
Old 05-25-2015, 02:42 PM   #118
My turn to ask. I tried the links to no avail, so here's my humble submission:
CDR-220
Model No: BE 4462
Serial No: X5023612
Thanks in advance.
Brian
jbm911 is offline   Reply With Quote
Old 05-30-2015, 11:54 AM   #119
Need Code
Here's the info I have...Thanks in advance!
CDR-220
Model BE 4462
Serial #: Y5044934
Bar Code: 4462G90Y5044934
jakeway is offline   Reply With Quote
Old 06-01-2015, 10:11 PM   #120
Are you able to do the CR-210 also?
Model: BE2182
Serial: V5004929
Thanks in advance!
leafdude555 is offline   Reply With Quote
