Old 04-23-2013, 08:09 AM   #1
Changing out wheel bearing. Anything else?
Got a noisy driver's side, rear, wheel bearing. Got the B90 tool to try and make it as easy as possible. Figured I would go ahead and change out the rear brake pads, on both sides, while I am at it. Already done the front's and flushed the old fluid. Anything else I should be doing/looking at while I am doing this project? Thanks!
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Kurt V is offline   Reply With Quote
Old 04-23-2013, 08:15 AM   #2
HAUSIDMT's Avatar
Look at your parking brake pads as well, since you will have the carrier apart. Also if you have gone to larger wheels, check parking brake cable clearances as well. Also check Conrtol Arms, ball joints, CV Boots/Joints etc. I found myself taking care of the lot while I was in there doing the same thing
Just my $.02
Haus
2002 Boxster S with a few goodies, my 2nd Porsche.
1st was a 1966 912 hand me down from pops
HAUSIDMT is offline   Reply With Quote
Old 04-23-2013, 04:03 PM   #3
Haus, those are some excellent suggestions!
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Old 04-24-2013, 04:32 AM   #4
Homeboy981
Homeboy981's Avatar
One more thing….CVs - while you're there.
Old 04-24-2013, 05:17 AM   #5
Christ. Just had a look at the Pelican guide to changing the bearing. What a palaver!
pothole is offline   Reply With Quote
Old 04-24-2013, 06:48 AM   #6
Yeah, I don't know why Wayne hasn't updated that tech article to show how to do it using the B90 tool. He even sells the tool on PP!
2003 Boxster S
1991 BMW 318is
'93 Ducati 900SS
'76 BMW R75/6
'73 Honda Scrambler
Old 04-24-2013, 06:56 AM   #7
Can you do it leaving the hub on the car with the tool?
Old 04-24-2013, 10:24 AM   #8
woodsman's Avatar
Yes. My Bentley manual says you can change the wheel bearings while they're in the car.
