Old 04-02-2013, 07:39 AM   #1
Black Stallion's Avatar
What is this bracket?
The title is pretty self-explanatory. I was tinkering with my new 2000 Boxster S, and I noticed this bracket on the right side of the throttle body. It looks there had been something there previously, as the threads are still really shiny. What is it for?
Black Stallion is offline   Reply With Quote
Old 04-02-2013, 08:03 AM   #2
Nimbus117's Avatar
There's a photo of one doing something on this thread:
http://986forum.com/forums/general-discussions/19773-air-oil-separator-problem.html
2003 Boxster 2.7L
2010 Civic Type R
Nimbus117 is offline   Reply With Quote
Old 04-02-2013, 11:58 AM   #3
Is that bracket doing something in the other picture? Every picture I've found seems to show an empty bracket. Is it for an option that nobody wanted?
Old 04-02-2013, 12:14 PM   #4
1999 base
Meir's Avatar
this bracket (AKA reteiner bar)has several functionalists.
1. anchor for engine support bar.
2. mount for e-gas TB bracket.
3. mount for PSE solenoid bracket.
edit: 4. bracket for tiptronic transmission cable.
Old 04-02-2013, 05:46 PM   #5
Carnut
AndyA6's Avatar
In my car it supported the throttle body. With the larger TB its gone.
'14 Boxster
Old 04-02-2013, 05:51 PM   #6
+1 for the TB
"You finally got that Nazi-go-cart you always wanted." -Peer
http://i40.tinypic.com/ei6sns.jpg
pompous is offline   Reply With Quote
Old 04-02-2013, 08:51 PM   #7
jaykay's Avatar
Hmmm if I put pse on my car will I have a problem with this not being there?
986 00S
Old 04-03-2013, 08:04 AM   #8
1999 base
Meir's Avatar
not really.
you can locate the solenoid wherever you want.
however, you will need it if one day you will need to do a clutch job.
that bracket is suppose to connect to the engine support bar.
i also found out that with tip trans there is another bracket that attached to it.
but you are not going tip right ?
Old 04-03-2013, 08:34 AM   #9
Porsche Chick's Avatar
That is clearly the upper income bracket.
Please immediately send 33% of your income to the government.
Old 04-03-2013, 11:39 AM   #10
jaykay's Avatar
not really.
It did look like an engine lift eye but I thought it to be way too thin!!
986 00S
Old 04-04-2013, 11:15 AM   #11
I guess I get that it CAN be used for a lot of things, but I don't see why it has those two empty threads on them. What bolts "originally" went through those threads, and why? If anyone has photographic evidence, I'd love to see it. At least one inquiring mind wants to know. Haha!
