Old 02-06-2013, 11:45 AM   #1
Question MOMO Shift Knobs
Ok, whats the deal, will Momo shift knobs fit on my 98 Boxster? On eBay, some sellers say it will, some say it won't. What's the deal??
navyc130fe is offline   Reply With Quote
Old 02-06-2013, 01:33 PM   #2
boxster6354's Avatar
You can fit a MOMO shift knob to the Boxster shifter but it will require you to round out the top of the shaft to fit, not a difficult thing to do with a drimmel and grinder bit attached.
As I have done myself.
boxster6354's Garage :: Monica
boxster6354 is offline   Reply With Quote
Old 02-06-2013, 03:28 PM   #3
Thanks, will "rounding out the shaft" be obvious when I see it?
Old 02-06-2013, 08:16 PM   #4
Yes it will be quite obvious, the MOMO knob is round and the stick of the box is rectangular so you will just round off the four corners a bit at a time till it fits.
Took me maybe 10-15 minutes with a dremel, make sure to wear gloves as it will get hot, also I did not do this while in the car, I had removed it as I was installing a short shift kit at the same time.
There is a write up on Pelican Parts.
Pelican Technical Article: Boxster Gear Shift Knob Replacement and Upgrade - 986 / 987
