Old 12-01-2012, 07:21 PM   #1
Better but still not running perfectly
Boxster 2000 S
Lately, the idle was bouncing a lot and shaking the car. When I was trying to drive a little hard, It feel like not much power and engine was often cuting power. When I depress the clutch, engine would die. Start again and was running ok, sometime ā good cloud of smoke.
Now, last week I changed the MAF and clean the throttle body, but no change. Tonight I changed the AOS (not that easy) and now idle is really good, but I still have engine power cut out. Still no code. Next step in 2 days, I will change the spark plugs and the fuel filter.
Anything else worth to check while I'll be under the car?
Tanks
Chris
wawa is offline   Reply With Quote
Old 12-01-2012, 07:37 PM   #2
Jager's Avatar
Fuel filter, fuel pump... When was the last time the filter was changed? Check your fuel preasure, pump may be going bad.
Jäger
300K Mile Club
Old 12-02-2012, 05:13 AM   #3
I dont know about the fuel filter but not since I own the car. So it will surely help.
How do I check the fuel pressure? Do I need special tools? I need to search about that on the web.
Chris
Old 12-02-2012, 07:06 AM   #4
Found fuel pressure procedure. Will change fuel filter in 2 days and see if I need to do it.
Chris
Old 12-02-2012, 07:34 AM   #5
kjc2050's Avatar
Please post a link...
Old 12-02-2012, 08:25 AM   #6
Its on Pelican Parts board
http://www.pelicanparts.com/techarticles/Boxster_Tech/19-FUEL-02_Sensor/OBD-II-scan.pdf
Chris
