Old 11-04-2012, 06:32 AM   #1
How low can you go topless
If it's not raining I like to go top down. My question is what would be the lowest temperature to go topless. I learned the hard way that plastic windows don't do well below 60 degrees F. Now than I have glass I would like to know what is the limit for the canvas itself.
opus69 is offline   Reply With Quote
Old 11-04-2012, 05:06 PM   #2
MN 986's Avatar
I also learned the hard way about cold temps and plastic rear windows a few years ago, but since then I retrofitted a 2004 OEM top with glass window to my 2002 Boxster and I have gone top down into the upper 30s more than a few times. Had the top down yesterday when it was sunny and 45. Hey, I live in Minnesota, so I have to ejoy any driving time I get before the snow flies!
MN 986 is offline   Reply With Quote
Old 11-04-2012, 05:25 PM   #3
keysguy's Avatar
all year long..in fact winter time is the only time I drop the top in daylight hours. It's way to hot to sit in the subtropical sun in the summer with the top down. I do drop the top in the evenings or at night during the summer
1979 911 Targa SOLD!!!!
1985.5 944 SOLD!!!!
2000 Boxster
keysguy is offline   Reply With Quote
Old 11-04-2012, 08:52 PM   #4
Multi-Boxer Driver
Deserion's Avatar
I've had it down when the temp. was below 32. At night. People looked at me as if I was insane.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 11-05-2012, 07:57 AM   #5
Check you Owner's Manual. Even with the glass window, it MIGHT say something about the proper temp, or running the heat, before moving the top in "cold" weather. I don't remember.
In my 987, with the top down, heater cranked, windstop, heated seats, sweatshirt, windbreaker, and a knit Chicago Bears hat on, I've done thousands of miles in the high 30's and low 40's. Sunny days. No rain.
About the only spot that gets cold, in the back of my neck. A rolled up towel is the trick for that chill.
Old 11-05-2012, 12:21 PM   #6
jcb986's Avatar
In my younger days, my wife and I would go topless in 30 degree weather. Windows up and heater on high, it was great. Had a 68' Corvette, Blue on Blue.
Old Hippie Young Heart
Old 11-05-2012, 11:48 PM   #7
MikeinLA's Avatar
Unless it's raining, I always have the top down, but here in L.A. it doesn't often get into the 30s (and it almost never rains). I have this cheap suede baseball jacket with a quilted lining that is an absolute WALL against the wind and it has a nice soft collar. I keep it in the front boot and it works wonders. That and a baseball cap and I'm good.
Mike
MikeinLA is offline   Reply With Quote
Old 11-06-2012, 05:06 AM   #8
My top cracked in 70 degrees. I don't put it down unless the sun was shining on it for a while, heating it up. 80 degrees+.
So in the 2 years I owned it living in PA mountains, I might have put the top down 10 times total.
00 2.7 5SPD MT
ProjectM96 is offline   Reply With Quote
Old 11-06-2012, 03:01 PM   #9
Autobahn Glanz
WhipE350's Avatar
I find here in NC it is more pleasent to go with it down when it is a little too cold then really hot as the summers always are here. In the summer mornings and nites or when you finally reach the high country it is pleasent. In the winter...well if the sun is out can go pretty low. I keep a ski cap in the pocket behind the seat, have heated seats, and can blast the heat too. A nice sunny midday 40s Nov/Dec/Jan/Feb temp is wonderful to drive in. Hey if I'm playing golf year round...then a midday ride in the old Box is doable too. I really don't enjoy the 2000 'S' with the top up anyway so the top really needs to be down. On the 2007 I don't mind the top up at times.
Old 11-07-2012, 06:36 AM   #10
70 is my cut off here in Michigan.
Below that I feel like the automotive equivalent of the morbidly obese guy who wears shorts into Wal-Mart in February when its 8 degrees. Not a look I care to cultivate, personally. But everyone has a different threshold.
d18mike is offline   Reply With Quote
Old 11-07-2012, 06:21 PM   #11
Autobahn Glanz
WhipE350's Avatar
Doesn't this give you only about 50 total days to drive your car in Michigan
Old 11-07-2012, 08:59 PM   #12
l3m
l3m's Avatar
Maybe the case in the Upper Peninsula but in lower Michigan, it can get past 70F in May through part of Oct. When I lived there, I rarely saw a Porsche with the top down.
'01 S
l3m is offline   Reply With Quote
Old 11-08-2012, 05:18 AM   #13
schnellman's Avatar
I thought the question had to do with lowering the top safely with a plastic rear window. My owner's manual says don't do it below zero degrees Celcius.
Old 11-08-2012, 11:14 AM   #14
I found out the hard way not to lower a plastic window when it's lower than 60 degrees. Now that it is replaced with glass I wanted to know what the canvas will tolerate. As long as it is not raining or lower than the 30's I like having the top down.
Old 11-09-2012, 12:35 AM   #15
There Is No Substitute.
rick3000's Avatar
70° F has always seemed to be the consensus for the lowest temperature for putting the top up and down. Occasionally, I take the hardtop off in the winter and go for a topless run through the mountains in 30° weather which is always fun!
Old 11-09-2012, 05:22 AM   #16
kk2002s's Avatar
Boy I hope the recommended 0 C in the manual is more accurate. Since this is my first winter I'm kinda hoping to do some 45 - 50 F top down driving when those rare days happen. I have been getting in the habit of starting the top down about 25% then help with my hand to get the Plastic window to fold/crease neatly instead of allowing it to bunch up in several directions. Then put it down the rest of the way. I notice that when I put the top up there are no crease lines in the plastic. I have driven 70 miles on the Turnpike in 55 F, top down, and that was enjoyable
Seal Grey
Old 11-09-2012, 10:26 AM   #17
CoBeerToad's Avatar
My rule is 50 F. But I find my self breaking that rule more often than not. Especially when I get out of work, but I park with the sun beating on the plastic window so after work, it's very pliable so I have no worries.
CoBeerToad is offline   Reply With Quote
Old 11-14-2012, 07:21 PM   #18
litteng's Avatar
lowest temp drive
was about -10 deg C, clear and dry, great trip into the office, but as soon as the snow flys , the black sheep went into hibernation...
claus
03-r1100s, 11-f800st, 09-987.2, Norton Commando
auf adlers fluegeln getragen
litteng is offline   Reply With Quote
Old 11-15-2012, 05:18 PM   #19
Gary D
Talking
Top, what top? That's why I have a convertible....
Only time it doesn't go out is when it's physically raining or snowing, then I take one of the Jags or the Jeep.
Gary_d is offline   Reply With Quote
Old 11-15-2012, 06:19 PM   #20
40 is about what I consider reasonable and comfortable with the heater blasting. I've not had any issues with the plastic rear window...
shadrach74 is offline   Reply With Quote
