Old 10-16-2012, 05:04 PM   #1
Current Cars
Bumperetts removal. What tools
So I'm going to take my number covers and have them painted. Is that just a regular Allen head to take them off or what tool do I need and what size. Thanks.
Current Cars
'01 Boxster (Sunday driver)
'02 F-150 Lariat (Mint, Stays in garage with the box)
'06 Civic (Wifes car)
'96 Jetta (Daily Driver)
Neekk1 is offline   Reply With Quote
Old 10-16-2012, 05:48 PM   #2
2001 Arctic Silver 2.7
tony_fury's Avatar
#6 metric allen
RMS, IMS, 87.5K
Old 10-16-2012, 06:11 PM   #3
Current Cars
Thank you!!
Current Cars
Old 10-16-2012, 08:36 PM   #4
Gforrest2's Avatar
This is a pretty easy DIY. See it here: http://986forum.com/forums/general-discussions/30418-4-hours-$50-later.html
Glen
Old 10-17-2012, 04:22 PM   #5
Current Cars
So I got one out and one is stripped ! Now what ?!?!?!? How can I get this out ??
Current Cars
Old 10-17-2012, 07:49 PM   #6
Gforrest2's Avatar
Well you can't put heat on it, but maybe a couple good squirts of PB Blaster, let it sit overnight, then jam a tight fitting screwdriver in the hex opening, put a pipe wrench or vice grips on the screwdriver and try to back it out that way. Or you could always drill it out.
Glen
Old 10-18-2012, 04:54 AM   #7
Homeboy981
Homeboy981's Avatar
Have you tried putting back pressure on the bolt?
In other words, get a small vise grip (in lessor cases you can use your finger - always a good place to start) or finger and place it on the reverse side on the head and push as you try to screw it out. I KNOW it sounds like I am describing something else, but stay with me here….
It is only Aluminum so even if you have to get mean with that bolt you should still be able to get it out! You may have to re-thread to a larger size, or replace the bracket but you should be able to "un-stick" by using a little reverse wrench-ology.
Good Luck and may all your bolts work free…goodness knows no one else is working or free in the US now (a little political humor there for election season).
