Old 10-03-2012, 01:45 PM   #1
Hunting for idle with a/c on
Guys,
today I am noticing that when the a/c compressor in engaged, the following symptoms occur in this particular sequence.
1) I will be driving in gear (can be any gear)
2) I put the car to neutral
3) When the car is neutral, the rpm counter goes down to around 400rpm, and this is also evident from the engine noise, sounds like it is about to stall.
4) RPM counter then jumps to 1000-1100 rpm
5) Settles at around 700 rpm.
This only happens with the a/c running.
Is it normal?
rene525d is offline   Reply With Quote
Old 10-03-2012, 01:48 PM   #2
What year and model of boxster?
Old 10-03-2012, 05:51 PM   #3
I think,,,after 2 Martini's (shaken,not stirred) that my car does the same. I keep thinking that the engine is going to stall, but it does not ,so I think that all the IMS stuff scares me and keeps me on edge.
milliemax is offline   Reply With Quote
Old 10-03-2012, 10:16 PM   #4
It is a 2004 S
Old 10-07-2012, 01:15 PM   #5
SDBxstr's Avatar
hunting for idle
I had the same issue on my 986 . I removed throttle body and cleaned with throttle body cleaner. now idling perfect!
SDBxstr is offline   Reply With Quote
Old 10-07-2012, 07:41 PM   #6
I am experiencing the same issue and have cleaned the TB to no avail... Please post back when you have tried this.
