Old 09-13-2012, 07:44 PM   #1
Changing "filters" help
Where is the "cabin filter" located in my 02 S and is it different than the intake air filter? I changed the air intake filter myself but was wondering if it is easy to change the cabin filter and how to do it? Appreciate any advice from all the experts as I am just learning my way around this fabulous automobile. Love this forum!
2002 Boxster S
Arctic Silver Metalic
Gray leather/Black Top
1olddude is offline   Reply With Quote
Old 09-13-2012, 07:51 PM   #2
The Radium King's Avatar
here you go sir ...
Pelican Technical Article: Boxster Air Filter / Pollen Filter Replacement - 986 / 987
2 minute job!
Old 09-13-2012, 08:05 PM   #3
Perfect! Thanks a million.
2002 Boxster S
Old 09-14-2012, 03:35 AM   #4
Nothing beats breathing clean air through the pollen filter with the roof down.
howe is offline   Reply With Quote
Old 09-14-2012, 07:44 AM   #5
schnellman's Avatar
Ah, yes. But, just think how much pollen you're taking out of the air!
Old 03-01-2015, 03:21 PM   #6
gomarlins3's Avatar
I just changed mine and the housing looks like it is suppose to have some sort of a lid. Mine does not however. Is there suppose to be a lid you remove after you take away the plastic piece held down with the torx screw?
gomarlins3 is offline   Reply With Quote
Old 03-01-2015, 04:02 PM   #7
1999 base
Meir's Avatar
No lid.
The large plastic cover acts as the lid.
Old 03-01-2015, 04:12 PM   #8
steved0x's Avatar
One tip is don't completely remove the screw, if you do the backing nut can fall down and out the bottom.of the car. The Bentley says to just loosen it and rotate the cover off.
Old 03-01-2015, 05:59 PM   #9
gomarlins3's Avatar
Thank you guys.
