Old 09-20-2005, 05:34 AM   #1
How do I quiet a squeaky hood?
I have noticed for awhile that my 01 Boxster squeaks over rough pavement at very low speeds and just recently while washing the car, the hood makes the same noise when I push down the front left or right sides of the hood. Is this a easy fix? I'm curious if the fix will also take care of my rough pavement noises. Thanks.
spgribben007 is offline   Reply With Quote
Old 09-20-2005, 08:10 AM   #2
deliriousga's Avatar
Use some white lithium grease. Take a Q-Tip and put it in the hinges under the hood. Also put some in the hinges of your top, but make sure you don't have globs of grease around that can get on the top material. That should get rid of your squeaks for a good while (do it annually).
You could probably use WD-40, but it won't last long and is easy to spray all over the place on accident so I wouldn't recommend it.
As for rough roads making noise, it'll take a Cadillac or other such luxury suspension. The Boxster's suspension is very tight so you'll get road noise in rough situations.
1966 Wife White/Brown Top
Old 09-20-2005, 08:13 AM   #3
deliriousga - Thanks for the fix-it advice.
