Old 08-22-2012, 06:06 AM   #1
tanque55's Avatar
Sticky Throttle
a month in with a 2002 S and the only complaint so far is a slightly sticky throttle. Doesn't bother me in 3 or higher gears but makes 1st and second a little tricky. I'm getting used to it but would like some tips on where to address this problem. It's like the cable has stretched and it hangs up just a little as the pedal is depressed.
tanque55 is offline   Reply With Quote
Old 08-22-2012, 06:59 AM   #2
I believe all boxsters from 00 or 01 are electronic throttle body. does not have cable.
most likely cause (without anything being broken) is that the throttle body needs cleaning.
sb01box is offline   Reply With Quote
Old 08-22-2012, 07:01 AM   #3
+1. Probably just a tad gummed up
Mighty Shilling is offline   Reply With Quote
Old 08-22-2012, 08:49 AM   #4
tanque55's Avatar
Thanks I'll look into that. Although I've wrenched every car, truck and motorcycle I've ever had, I'm a little intimidated with this one. Just getting to the engine seems complicated. I need to get me some manuals any bible that you suggest?
Old 08-22-2012, 09:43 AM   #5
BYprodriver's Avatar
Cleaning the T/B is the 1st thing you should do, Porsche eliminated throttle cables in 2000. The Bentley publishers manual is a good start. With your experience just remove the top engine cover & you will see the T/B right there, remove intake tube & clean with Brake cleaner. You can hold the throttle open with your fingers & scrub inside with a clean rag. This does wonders for your idle speed.
Old 08-22-2012, 09:56 AM   #6
tanque55's Avatar
Thanks, that is exactly the kind of information I was looking for. I appreciate the tips.
Old 08-22-2012, 10:01 AM   #7
You are welcome. You can do a better job if you remove the T/B, just be sure you have a good QUALITY 5mm hex/allen bit to do that. There is a seal but I have reused mine many times.
Old 08-22-2012, 11:18 AM   #8
jcb986's Avatar
Pelican Parts, Wayne has a good handbook for your Boxster and it's cheaper than a Bently manual. Covers just about all the basic stuff and more.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 08-22-2012, 11:24 AM   #9
The Radium King's Avatar
and for free ...
Pelican Parts - Porsche Boxster 986 / 987 and Carrera 996 / 987 Technical Articles
and
Manuals - Porsche
