Old 08-13-2012, 12:50 PM   #1
Can anyone explain these codes??
These four codes came up after a loss of power. Not sure what was
the cause other than possibly bad fuel.
(see this earlier post)
http://986forum.com/forums/general-discussions/36771-bad-fuel-symptons.html
P1125 - Oxygen sensing adaptation, upper load range, cyl. 1 - 3
Short to ground / below lower limit / lean mixture threshold
Short to B+ / above upper limit / rich mixture threshold
P1126 - Oxygen sensing adaptation, lower load range, cyl. 1 - 3
P1132 - Oxygen sensing adaptation, upper load range, cyl. 4 - 6
P1133 - Oxygen sensing adaptation, lower load range, cyl. 4 - 6
Would a failing fuel pump trigger any codes?
986Porsche986 is offline   Reply With Quote
Old 08-13-2012, 12:58 PM   #2
Potential causes:
– Incorrect signal from MAF sensor
– Intake air system leaking
– Fuel pressure too low
– Volume supply of fuel pump too low
– Fuel injectors fouled
Old 08-13-2012, 01:01 PM   #3
The computer is saying that it cannot adjust (adapt) beyond the lower limit. This means that the O2 sensors are detecting an extremely lean condition so there is either too much air getting in (air leaks), or too little fuel (bad fuel pump (pressure or flow) or clogged injectors, or the sensor (MAF) is broken. The MAF is the chief suspect in this lineup.
Old 08-13-2012, 02:22 PM   #4
Topless's Avatar
More info on this:
P1123, P1125, P1128 codes - 986 Series (Boxster, Boxster S) - RennTech.org Forums
http://www.renntech.org/forums/index.php/topic/21009-fault-code-1126-1133/page__p__108636__hl__%221133%22__fromsearch__1#ent ry108636
It looks like a dead MAF.
Old 08-13-2012, 03:12 PM   #5
thanks for the info. Now the car takes about 15 to 20 seconds of cranking before it starts sputtering and barley fires up. Once its started it runs pretty rough for the first couple of minutes, then it idles with no problems at all. I just changed my spark plugs about one week ago. I did contact the local agricultural department and they are sending an inspector to the Chevron to inspect the fuel on Tuesday. They are also going to get about a quart of fuel from me from the drained tank. In my honest opinion, it seemed to me like the gas that I pulled out of the tank was not very strong in odor like gasoline should be. I guess at this point, I will wait for their results and then if the gas tests show nothing wrong, then I am thinking the fuel pump might be the problem.
Would the car have trouble starting right away if the MAF sensor was bad?
Old 08-13-2012, 03:15 PM   #6
Yup, sounds like MAF
mump is offline   Reply With Quote
Old 08-13-2012, 05:18 PM   #7
Topless's Avatar
Simply unplug the MAF. If the car runs better you found the problem. If the car runs no better... keep digging.
Old 08-13-2012, 08:09 PM   #8
Unplugged the MAF and the car still dosent start right away. I will take it for a drive tomorrow and see how she runs.
Old 08-13-2012, 09:17 PM   #9
2001 Arctic Silver 2.7
tony_fury's Avatar
For what it's worth...
I had a friend on a motorcycle trip across country, purchased fuel in Alburquerque and his motorcycle died on the freeway. Had to have it towed, found that he gotten water down fuel. Had to drain the tank and get new fuel to get his bike running again.
RMS, IMS, 87.5K
Old 08-13-2012, 09:39 PM   #10
im not surprised. that seems to happen often in new mexico. sigh..... i sure miss arizona. :ah:
