Old 07-24-2012, 08:01 PM   #1
golonaus's Avatar
Headlight problem. Won't come out. Alen spinning around
As title says
Tried to use the tool to remove headlight but it will turn around and around
Headlight it self won't move
Any ideas???
Never did it before so I dont know how the locking system works or looks
Happy speeding
Old 07-24-2012, 08:29 PM   #2
SPB racer
In the 98 there are two screws quite close to each other. One is the adjuster, which would just turn if attacked and if you weren't looking would appear to be doing nothing. The other is the removal system, which (in my 98) requires a 6mm hex socket. Are you sure you are turning the right one? The only reason I ask is because you mention a "alen" in your title. If you have the right one it will only take about a 90 degree turn to dislodge the headlight. The driver side needs to be turned anti clockwise and the passenger side clockwise. Hope this helps.
Laurie
Jittsl is offline   Reply With Quote
Old 07-24-2012, 08:45 PM   #3
Yeah, this happened to me the first time...was in the wrong hole. Mine has big round rubber plugs in the removal holes and oval flaps in the adjuster holes.
It's blurry, but clear enough. It's the round knobbed one.
Old 07-24-2012, 08:56 PM   #4
golonaus's Avatar
Yeah
I used the one with big rubber plugs
I'm saing alen couse this thing that is in the hole looks like alen ;-)
Old 07-24-2012, 09:00 PM   #5
That's strange...iirc its one solid bar with a hex head, so that would mean that either the bar or tool is stripped.
Old 07-24-2012, 09:07 PM   #6
I just popped my headlight out and checked. It's definitely one solid bar and only rotates 180 degrees, even with the light removed, so something may be stripped.
Old 07-24-2012, 09:10 PM   #7
golonaus's Avatar
At first my touts exactly
But no!!!
Is there any way to acces the headlight by removal of the fender???
I'm afraid that some 5$/hr mechanic fixed them in place
Previous owner was an idiot!!!! Seriously
Old 07-24-2012, 09:11 PM   #8
golonaus's Avatar
Thx man
Will try to work it out tomorrow somehow
Will post what happened after I'll figure it out
Old 07-25-2012, 06:41 PM   #9
Multi-Boxer Driver
Deserion's Avatar
I would suggest using a ratchet w/ extension to access the latch head to check before buying any new parts. In my case, I thought I had a stripped locking mechanism when it was only a stripped access tool! Tool was junk, using a ratchet now and everything works perfectly.
-Chris
2004 Porsche 911 C4S Cab
1991 Porsche 911 C2 Targa 3.6
2017 Subaru Outback 3.6R
Old 07-25-2012, 07:56 PM   #10
golonaus's Avatar
Thx to all
Got it resolved
My tool wasn't original and was wrong size
Too big
I looked up the tool on the Internet and mine is different
Lights are off he car!!!!!!
