Old 05-24-2012, 07:22 PM   #1
Send a message via AIM to Uptopar1952 Send a message via Yahoo to Uptopar1952
Wheels to fit boxster 2000S
Trying to find out if 97 Carrera wheels will fit my boxster. Wheels are 18x8 and 18x10. Anyone know if they will fit without adapters?
Uptopar1952 is offline   Reply With Quote
Old 05-24-2012, 07:35 PM   #2
copsahl's Avatar
Do you know what the offsets are? Something in the range of 40-46mm would fit well.
copsahl is offline   Reply With Quote
Old 05-25-2012, 08:00 AM   #3
Rears will need spacers if they are stock 993 18s. Debatable what looks best but you'll need 15mm at minimum up to 25 if you want really aggressive look. I have 18mm if I remember correctly and I like where they are. Use spacers with lugs and nuts not flat spacers
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
Old 05-25-2012, 01:45 PM   #4
Fronts are 50mm. Rear 47 on boxster. Carrea front same 50mm rear 52 mm according to dealer.
Old 05-26-2012, 08:39 AM   #5
copsahl's Avatar
smshirk is correct, fronts will be ok as is, rears will need 15mm+ spacers.
Old 05-26-2012, 08:55 AM   #6
walt2810's Avatar
Agree with smshirk. Installed 996 wb turbo look II rims 18" on my99 Boxster and the fronts were good but used 25mm oem Porsche spacers for rear which provides an aggressive stance. The hard part was finding the oem spacers!!! Good luck.
walt2810 is offline   Reply With Quote
