		|  05-15-2012, 06:23 PM | #21 |
	| Registered User
			we pulled the weights off before we sprayed, rebalanced and then installed. In the future we will simply put new weights where the old were, or, put them right over the sprayed area.  I doubt anyond would notice.
thanks!
				__________________2001 Seal Gray 5-Speed - 2007 Yamaha R6 - 2003 Honda Civic EX - 1999 Nissan Frontier XE - 2003 Coleman Utah
		|  05-16-2012, 04:37 AM | #22 |
	| Registered User
			Is the coating somewhat textured or is it very smooth for you?
		|  05-16-2012, 06:54 AM | #23 |
	| Registered User
					Originally Posted by Highlow  Is the coating somewhat textured or is it very smooth for you? |
You can do either, depending on the distance the spray gun is held from the surface.  With this particular color, my cousin painted his Acura TL from about 14 - 16" which resulted in a rougher, more matte-finished appearance.  He then stripped that off and repainted from about 6" which resulted in a very smooth, almost satin look.
My wheels were painted at about 6" and have a smooth, uniform appearance.  I'm absolutely pleased with the result, doesn't look cheap or "rattle-can" like.
[IMG]  [/IMG]
		|  05-16-2012, 07:26 AM | #24 |
	| Registered User
			Looking Good. You should consider Plastidipping the front grills in the bumper.
 If you don't like it, you can always peel it off.
				__________________00 2.7 5SPD MT
		|  05-16-2012, 07:31 AM | #25 |
	| Registered User
			That's on the list now, noticed that needed to be done in this picture!  I should be able to do that with just a can.
		|  05-17-2012, 02:27 AM | #26 |
	| 07 Carrera S Cab
			Curious...Since it's almost the same effort in terms of taking the wheels off, cleaning them, and then spraying them, why not just spray them with paint (which is a more permanent solution), than to plastidip them? Won't the plastidip come off rather easily when pebbles/road debris hits it from highway use?  Looks nice btw...
				__________________Current: 07 Carrera S Cab in Midnight Blue
		|  05-17-2012, 04:14 AM | #27 |
	| Registered User
					Originally Posted by Boxtaboy  Curious...Since it's almost the same effort in terms of taking the wheels off, cleaning them, and then spraying them, why not just spray them with paint (which is a more permanent solution), than to plastidip them? Won't the plastidip come off rather easily when pebbles/road debris hits it from highway use?  Looks nice btw... |
No one wants it to be permanent. I have been driving with Plastidipped wheels for a year now. No problems with pebbles or road debris taking the plastidip off.
When it comes time to sell the car, it is worth more in original form.
And painting is much more expensive and requires sanding.
		|  05-17-2012, 05:12 AM | #28 |
	| Registered User
			Yep, a lot of what he said.  This stuff is what they use to dip your tool handles in.  It's actually very tough and temperature tolerant.  It will not scuff or tear from small rocks hitting it.
 And it is significantly more effort to paint than use this product (having painted wheels before).  And now, if i scuff one on a curb, I just peel it off and spray it again for $20.
		|  05-17-2012, 08:26 AM | #29 |
	| Custom User Title Here
			Will this cover deeper curb rash gashes, or will they need to be smoothed out first?
				__________________https://youtube.com/@UnwindTimeVintageWatchMuseum
		|  05-17-2012, 08:35 AM | #30 |
	| Registered User
			You'll need to smooth things out, or fill them in if they're deep, first.  I've bondo'd wheels in the past before painting and been pleased with the results.
	|  Posting Rules |
		You may not post new threads You may not post replies You may not post attachments You may not edit your posts
 |  |  |  All times are GMT -8. The time now is 08:01 AM.
