Old 03-15-2012, 10:48 AM   #1
Parts required/recommended during IMS replacement
Gents,
Am going in for the fix that will stop my nightmares. Just wanted to check with the folks who have done the IMS replacement what all I need in order to have this done without finding myself dead in the tracks for want of parts. Please let me know if anything else is required or recommended to be changed. Thanks,
1. IMS bearing
2. LN IMS toolkit
3. 3 pcs - Intermediate Shaft Micro-encapsulated Cover Bolt
4. Seal for Intermediate Shaft Flange, Late type seal (4 mm thick)
5. 2 pcs - Camshaft End Plug (mine is 2000 S)
6. Case of beer
7. Medical Mar....
I also plan to attack the RMS and the clutch which I guess will only know when its out in the open. But, any advice regarding that is appreciated as well. Good thing is that the axles are out, engine compartment is open, suspension is out etc.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
1990 Land Rover Defender 6x6
Old 03-15-2012, 11:20 AM   #2
manolo's Avatar
New flywheel bolts.
Clutch guide tube, and the other various little springs/etc that get installed. Check Pelican.
I did a clutch slave as well.
Tranny oil (OEM)
Newer style cam chain tensioners (optional)
Lube that goes on the RMS (forgot the name) Check Pelican.
Lube that goes on clutch guide tube (ditto)
Thats all I can remember off the top of my head
2003 Cayenne Turbo
manolo is offline   Reply With Quote
Old 03-15-2012, 12:01 PM   #3
1999 base
Meir's Avatar
hi Bala.
about # 7 in your list, it doesn't have to be medical. any type will do the job.
jokes aside, i'm sure our friend Feelyx will be happy to get your old IMSB if you put it in a ziplock bag right after you remove it.
Who has done an IMS change? - Pelican Parts Technical BBS
good luck man, and let me know when you done. i will be happy buy the LN tools from you.
Old 03-15-2012, 12:10 PM   #4
hi Bala.
Medical is the way to go. How else can I get my insurance company to pay for it?
Anyway there seems to be a lot of interest in the tool and not (none so far) willing to sell. They can't be that greedy! I think I'll start a loaner program. Have the wheel bearing tool as well.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 03-15-2012, 03:24 PM   #5
1999 base
Meir's Avatar
sad
the only reason i asked, is because i saw your other post looking for the tool.
i was sure someone sold it to you by now.
i guess people want to hang to it thinking they will have to use it again in the future (make sense in some way).
Old 03-15-2012, 04:17 PM   #6
Nothing materialized yet. One more day and I'll have to buy it from Pelican.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 03-16-2012, 01:20 PM   #7
crogers106's Avatar
I just had this project completed and ended up replacing the dual mass flywheel while we were in there. Also took this opportunity to install LN's magnetic drain plug & spin on oil filter adapter. Before they give you back the car, make sure they check that the exhaust heat shields don't come loose when they remove/reinstall the exhaust. I had that happen and it sounded terrible & scared the heck out of me & had to take back to the shop to fix.
crogers106 is offline   Reply With Quote
Old 03-16-2012, 02:18 PM   #8
I got the IMS Guardian so, that comes with the magnetic plug.
Interesting about the heat shield. I did not have to remove mine. Just dropped the tranny. I guess you are talking about the one over the cats? I do have the entire suspension, muffler, bumper removed BTW.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 03-16-2012, 02:58 PM   #9
crogers106's Avatar
The ones that came loose on mine were not the ones over the cats but the ones that wrap the pipes before the cats. Somewhere during the procedure these broke loose and you wouldn't believe the noise they made. See my recent post (lets play whats that noise) Just sharing a lesson learned. Even though my IMS was fine, there was no way to know that and now it's easier to sleep and I love the car even more. Best of luck!
Old 03-16-2012, 03:48 PM   #10
I have so many things off the car it's going to a crazy making sure everything is back in place and torqued up right. Thanks for the heads up.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 03-17-2012, 10:10 PM   #11
ohioboxster's Avatar
Are you replacing a good bearing? It didn't fail or there's no sign of failure correct?
2002 TT
Old 03-18-2012, 04:41 AM   #12
Not sure if it is good. No sign of failure but, Durametric reported a CS deviation of over 6 in one and 5.6 in one. Steady at idle though. Car is at 90k so would be prudent to check and replace anyway since i am in there. Glad i droped the tranny as rms is leaking, clutch needs replacement too.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
Old 03-18-2012, 10:55 AM   #13
manolo's Avatar
Just FYI, I have an LN IMS tool kit that I would be willing to sell. Was going to keep it but doesn't look like I will need it anymore. I know it's a little late for you, but if anyone else needs one shoot me a PM.
2003 Cayenne Turbo
Old 03-18-2012, 11:18 AM   #14
Porsche "Purist"
Paul's Avatar
You'll need some green locktite and some RTV.
This is before I cleaned it up.
1987 924S. 2002 996TT. PST-2
Old 03-18-2012, 11:23 AM   #15
Porsche "Purist"
Paul's Avatar
Good idea to replace these too:
Old 03-18-2012, 11:30 AM   #16
Porsche "Purist"
Paul's Avatar
I usually break at least one of these while trying to remove the shift cables.
Old 03-18-2012, 11:37 AM   #17
Porsche "Purist"
Paul's Avatar
You may need a 10 mm Stubby triple square for one of the tranny bolts.
This set has the correct one plus the proper one to remove the tranny drain plug.
BLPXZNM389, Set, Socket Driver, Metric, Triple Square, Stubby XZN, Blue-Point, 9 pcs.
16mm security plug for tranny (included in set)
BTW the part numbers in my posts above may or may not fit your car, check PET for your specific year/model.
Old 03-19-2012, 08:43 AM   #18
Paul,
I did not have to remove the exhaust or the shift cable links. I popped them out of the lever and then the plate with 2 bolts holding them. Those clips seemed like a PIA though.
2012 Panamera 4
2010 Boxster
2000 Boxster S 3.2L
