02-13-2012, 01:04 PM
Question about clutch
I had a squeal from the back of the car every time I would start moving (release the clutch). Squeal would appear only after car was parked for more than 2 days and would go away after a warming up, it turned out to be new belt that I put in 1 year ago.. however I was so sure it was clutch that I started paying a lot of attention to it.. and now I think something is wrong with the clutch
When releasing the clutch it seems that its a two stage release, it catches first very close to the floor then very high, with pedal almost de-pressed.
IF I rev the engine it's smooth, however when starting at 1500 RPMs is feels like the clutch catches, car starts moving, then almost chokes, then it catches again
Is it normal? Do we have a 2 stage clutch?
Funny how before I never noticed it and was driving fine.. now it drives me crazy!
I have a 2000 Base Boxster with 80K miles on it
Sasha
02-13-2012, 09:45 PM
No, the Boxster does not have a two-stage clutch. What you describe makes me think of clutch judder where the friction slip is not linear resulting in uneven take-off from a stop. Judder typically occurs when the surface of the friction plate engages the flywheel unevenly.
IF (and that's a capital IF) clutch judder is the problem, one way to adjust for this in the short term is exactly what you've been doing: apply a smooth increase in throttle as you let the clutch out and avoid slipping the clutch any more than necessary. The throttle and the clutch actions should be smooth, linear, and nicely timed. In the long tern, the problem will get progressively worse and the clutch will likely need repair.
02-13-2012, 10:47 PM
Ex Esso kid
When you are approaching hills take note of whether the clutch slips on a steep grade, if it does than it is going to need replacement soon.
02-14-2012, 08:29 AM
Thanks for replies,
Clutch is not slipping, I tested it many times.
That's what bothers me, clutch seems to be good, yet has this weird problem.
Sasha
02-14-2012, 08:45 AM
Ex Esso kid
How bout the engine mounts? If they are really bad the shifting of the engine will make that kind of problem.
02-15-2012, 01:26 PM
I looked up the term "clutch judder" and it seems that in my case problem was either condensation or glazing.
I burned the clutch as bit and it feels great again
I also cleaned my throttle body (again) and it was dirty as hell..
I cleaned it a less the 6 month ago when I installed technotorque and now it's dirty again..
What would cause throttle body to get dirty so fast?
I have new air filter, that should do the trick right?
Sasha
PS: GhostRider, I don't think it's engine mount related, I replaced my engine mount 1 year ago
02-15-2012, 02:23 PM
Ex Esso kid
sasha055, car has three mounts not just the front.
02-15-2012, 02:38 PM
Are other two mounts are prone to breaking too?
Front mount seems to be a fairly common problem.. I never heard of rear mounts going bad.
Is there a way to test if the rear mount is broken or not?
Sasha
02-15-2012, 03:15 PM
Ex Esso kid
The other two mounts use a gel or fluid filled technology that dries out over time and allows for play in the mount, at least that is what I read. The 944 used a similar fluid filled mount that was prone to the same weakness.
02-15-2012, 05:02 PM
2001 RUF 3800S
I experience the same type of squealing you do but it was after my stage 3 clutch and aasco LWFW, apparently thats common but annoying as $%^#
IG: RUF3800S
02-15-2012, 08:21 PM
Autobahn Glanz
When you did it 6 months ago...is that when you put in the new filter?...and it got dirty again? Very strange. When you say dirty was is black oily stuff or hard carbon like? When I got my car little over a year ago (53k miles) I cleaned mine and it was spotless, previous owner never did it, it was a fun project anyway but not needed. What type of filter are you using, is it one that is oiled?
02-16-2012, 08:06 AM
Whip:
It was carbon type black sludge that I had to scrub of the throttle body.
I had K&N oil filter before, 6 month ago I changed to OEM paper filter.
It's weird, the only thing that comes in mind.. I de-snorkeled the car at the same time when I changed filter.. maybe it has something to do with it..
violametallic: I don't think I have lightweight flywheel, I have no history of the car before I got it.. but I discovered that previous owner didn't know what car maintenance means
Anyway, this story has a happy ending, something did it.. either burning the clutch a bit or cleaning throttle body.. my clutch feels brand new now!
Thank you all!
Sasha
