Old 02-12-2012, 06:42 PM   #1
Do I need extra parts for rear wheel bearing replacement
First and foremost.....Greetings from the desert.
So I'm planning on replacing both of my rear wheel bearings upon my return from my deployment. Before I left I had the car checked out by a local mechanic and was told it sounded like right rear bearing is goind out. So I figured might as well do the left side also and at the same time, since the suspension is pretty much out, also put in new strut and brakes. My question to ya'll is: What other wearable items should I replace while the suspension is out? Any other seals, rubber gaskets, etc. I want to have everything ready for him and not delay the momentum. Do what the mechanic to say: "oh, you will also need...blah, blah". I like being prepared.
'01 Box S with 91k miles
442nd986s is offline   Reply With Quote
Old 02-12-2012, 07:01 PM   #2
Spinnaker's Avatar
Although it is pretty obvious, once you get it all apart, CV Boots.
Old 02-13-2012, 05:57 AM   #3
It's a good time to think about bushings. My suspension started feeling a little soft at 100,000 and by 120,000 it felt downright dangerous. New bushings and struts (and bearings) all around put things back in order.
Wret is offline   Reply With Quote
