Old 01-10-2012, 01:01 PM   #1
Bmod986's Avatar
Failed at the first step of de-snorkeling. some help please
ok so i tried to take the vent off so i could reach the tube and i failed. the bottom part of the blinds wont budge and i thinks i snapped one corner of the top blind. So what now. I took out the screw and wiggled everything to try to make it move. Im afraid il break something else. I even applied some wd-40 to see if it would loosen up. One question is can i pull the outer vent without pushing the blind or will that brake the brackets?
Bmod986 is offline   Reply With Quote
Old 01-10-2012, 01:17 PM   #2
Ex Esso kid
The blinds have little nubs on them that you can't see. Like many other Porsche parts, they unlock in a specific sequence. It's a gentle push in and then you move them laterally to release the nub from the hold. If memory serves correct, it's a down and to the left movement. As you already discovered they are delicate, so work it like a puzzle, gently and you should have success. Once you see it apart the reverse is easy.
Old 01-10-2012, 06:34 PM   #3
Jager's Avatar
This picture might help...
Jäger
300K Mile Club
Old 01-11-2012, 03:12 PM   #4
Bmod986's Avatar
Thanks for the help but i still cant push the blinds back. I even hit it with a hammer a few times. Softly but still it didn't budge. I know i have to start from the bottom but it just wont move and I dont't know how much stress that hing can take before it breaks. Im still going to try it but I just want to make sure its done right and i dont have to end up buying a new vent piece.
