Old 07-28-2005, 01:02 PM   #1
need advice on purchasing 2001 boxter S
Hi! I have been up all night debating on purchasing a 2001 Boxter S. I believe the price is pretty good ~27K for 35K miles. The ignition switch has already been changed out. the clutch was replaced a year ago and the tires have 8K miles. Sounds like the owner has cared for the car well.
My concern is that I need to understand what is involved with maintaining the car. Are Porshes notorious for repairs. What can I expect to pay for Tires, oil changes and etc. Are extended warranties a good idea?
I have a decent job but do not have money to burn on a car, so I am fearful of purchasing the car at this time.
any advice?
lorannb is offline   Reply With Quote
Old 07-28-2005, 01:38 PM   #2
deliriousga's Avatar
Are you planning on maintaining it yourself or having a shop do it? That's the biggest difference in maintenance costs. Let me know and I'll give you some examples of costs.
1966 Wife White/Brown Top
Old 07-28-2005, 02:34 PM   #3
The work would be done by a shop
Old 07-28-2005, 02:52 PM   #4
donv's Avatar
I'd definitely have it checked by a competent Porsche mechanic first. You say "Sounds like the owner has cared for the car well." - how do you know? They should be able to show you records to prove it.
I don't want to scare you needlessly, but what are the current owner's driving habits?
From the number of miles on the current tires I'm guessing this is the third set of tires (8K off 35K means if it was just one set prior, they lasted 27K miles - probably on the high side for Boxster tire life) . Third set makes more sense to me when combined with a clutch replacement by 35K miles. This possibly suggests a car driven hard... nothing wrong with that, these are performance vehicles!
It could be that this truly is a cream puff that is driven very easily just to country club dinners (leading to looong tire life) that just happened to have a clutch problem show up. It happens.
The mechanic (and service records) should be able to help you tell the difference between the two opposing views.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
Old 07-29-2005, 04:57 AM   #5
Like Don said, have a local dealer do a PPI on it, top to bottom. I would not buy any car without that. If the seller says he's offended, he's hiding something.
If you are going to drive it regularly putting more than average mileage, then don't cut it close budget wise unless you are willing to do some of the work yourself. Regular maintenance is not cheap, even at a Porsche specialist who's not a dealer.
At a shop here are the things I've had done and costs:
1) 30K service: $800+ at dealer (Oil, oil filter, air filter, cabin filter, spark plugs, check serpentine belt, check hoses, check/lube top)
2) 45K service: $250 at Porsche specialist shop, not a dealer (Oil, oil filter, minor checks)
3) Quoted $1400+ to replace coolant reservoir in rear trunk. Did it myself instead for $400 total parts, coolant, hoses.
4) Replacing all of my rollers in the serpentine belt line. The bearings are all wearing out and making racket. Parts are $150 w/ me doing it myself. Since I got the parts at Sunset Porsche, your local dealer will probably charge what mine does and that's $280 for parts. Even though it takes about 30 minutes, it's probably a 2 hour charge in labor so add $240 for a dealer to do it.
5) Replaced ignition switch. I was quoted $400+ for this job at the dealer because they will only put in the revised switch which requires the new key tumbler and re-keying it to match your keys. I could replaced the switch with $30 in parts in 30 minutes so I did it myself.
6) Quoted $100 for just an oil change at a local shop.
7) Tires last 30K miles for me. It will mostly depend on your driving habits. I use Kumho tires at a cost of about $140 each installed.
8) I saw on another forum where someone was quoted $4K for a clutch job at a dealer.
They have a long period between required service, but if you don't check things like the top joints, etc. between times you will end up with problems over time.
If you go to a dealer for service, it's $100-$120/hour labor. At a Porsche Specialist shop it will be $70-90/hour and you should get references from other owners before taking your Boxster in to them.
Most other mechanics will not touch a Porsche. Even if you can find one, you probably don't want them tinkering with the car. When I told my friend who is also my mechanic for the other cars I wanted to get a Boxster, he said he would not touch it even for a friend.
Good luck in your hunt!
Old 07-29-2005, 05:31 AM   #6
Porschekid's Avatar
Having a Porsche mechanic check over it is a must. It was well worth it when I bought my Boxster. Good luck, when you find yours i'm sure you'll love it.
http://www.thecarspace.com/photos/8/...1481113d25.jpg
When people risk their lives, shouldn't it be for something very important?
Well, it better be.
But what is so important about driving faster than anyone else?
Lots of people go through life doing things badly. Racing's important to men who do it well.
When you're racing, it's life. Anything that happens before or after is just waiting.
Porschekid is offline   Reply With Quote
