12-10-2011, 06:01 AM
What tire pressures do you run? (street)
I've been fooling around with tire pressures and now I'm kind of confused. What tire pressures front/rear are folks using for general street driving? I'm trying to get sort of a balanced, nimble feeling and the stock pressures make my car understeer.
When I read some old posts I get conflicting information about whether the front/rear bias gives more or less understeer.
12-10-2011, 06:14 AM
Front : 235/35/19 32 psi
Rear : 275/30/19 36 psi
12-10-2011, 06:29 AM
I agree, 29 in the front is too low in my opinion, I run 17 inch tires and like between 31 and 32 in the front and 36 in the back.
2001 Boxster S 3.6L, Zeintop
12-10-2011, 06:32 AM
I shoot for 34 front and 36 back when at operating temperature.
-Chuck Patterson
12-10-2011, 06:36 AM
19" Carrera Classic wheels. PS2 tires. About 1 PSI below OEM spec, cold tire pressures. Nitrogen.
12-10-2011, 07:24 AM
front: 225/40-18 @ 32psi
rear: 265/35-18 @ 36psi
12-10-2011, 07:57 AM
I run close to factory recommended pressures.
02 Boxster (DD sans kids)
08 Corvette Z06 (Track car)
12-10-2011, 11:24 AM
32/32. At 29/36 I had very noticeable lift throttle oversteer in any sweeper.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
12-10-2011, 04:55 PM
Street
225/45/17 29psi Front
255/40/17 33psi Rear
Hankook Ventus R-S3
Track
225/45/17 32psi cold/37psi hot Front
255/40/17 33psi cold/38psi hot Rear
Nitto NT-01
12-11-2011, 03:25 AM
Street only, 32 F / 37 R.
78%N2, 21%O2 mix
'98 Artic Silver w/ Tip
12-11-2011, 06:35 PM
Matt
I run recommended (per the manual) pressures, no problem.
12-11-2011, 06:50 PM
Porscheectomy
78%N2, 21%O2 mix
LOL, I understand it's good to put a little Ar, CO2 and H2O in that mixture.
12-11-2011, 07:35 PM
I try to run factory spec but once the tire warms up tire pressure goes up signficantly during summer months. Took a long drive to Flagstaff last Sept from the Bay Area and had to drive thourgh Mojave desrt. Saw my tire pressure go up as much as 4 psi front and rear. Winter months seems it doesn't go up as much.
Now I run 30 up front and 34 at the rear.
2008 Boxster S PDE2
12-11-2011, 07:59 PM
Lift throttle oversteer will occur in any turn, especially at the track.
12-11-2011, 09:55 PM
+1 Lifting in the middle of a fast sweeper is like pressing the ejection button. It works every time.
Regarding the OP, I usually run 32/32 cold on the street. Running 29 up front will add a little ride comfort but not much noticeable change in handling.
12-11-2011, 11:23 PM
Maybe I'm just unconsciously compensating with steering for trail throttle oversteer, but it is very pronounced with 29/36 psi and essentially non existent when I run even pressures.
Current car
Previous cars
1973 Opel Manta
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1993 Saab 9000
12-12-2011, 05:45 AM
Thanks for the replies. I tried 35 all the way around but the car rode too rough over cracked pavement. What I'm trying to understand is how the front/rear bias changes understeer. I always thought a low front tire pressure was kind of a bandaid to create understeer because the car companies felt that was best for their customers. Probably they arre right, too. I think Corvairs had unbelievable tire pressures - something like 15 psi on the front and 26 on the rear.
When I bought my car a year ago I was impressed with the neutral steering and when I checked the tire pressures, the previous owner had a reverse bias with roughly 35/29. I would have kept it that way but one of the fronts was cupped and so I bought new fronts only. Unfortunately I picked a "grand touring" tire instead of a sports car tire. I'm pretty sure that is the root of my handling issues. I test drove a newish Miata and it steered ten times as good as my Boxster. The new rear tires I just put on are the same brand (Kumho) but they are more of a sports car tire. I think I need to get something better for the front.
12-12-2011, 06:58 AM
I run 30 all the way around. With coil overs, 36 in th back is just too jarring.
12-13-2011, 07:03 AM
07 Carrera S Cab
78%N2, 21%O2 mix
That's only 99%. What's the last 1%?...hot air?
12-13-2011, 08:34 AM
30 / 34..........
986 00S
