Old 11-17-2011, 06:50 PM   #1
Laquer thinner or denatured alcohol to remove airbag stickers?
I picked up both Denatured Alcohol and Lacquer Thinner to remove the silly airbag stickers on the visor. Which is better?
"Better" is defined as: will most quickly remove the sticker AND do no damage at all to the visor?
Many thanks,
Ron
ChairmanRon is offline   Reply With Quote
Old 11-17-2011, 07:23 PM   #2
Jaxonalden's Avatar
Nether, buy the black air bag stickers on eBay and put them on top of the stickers. They work great, mine have been on for three years.
Old 11-17-2011, 09:49 PM   #3
Registered Boxster abuser
healthservices's Avatar
What was wrong with the wd40 I used and suggested? Is ten minutes too much work?
Old 11-18-2011, 03:36 AM   #4
Denatured alcohol. Rubber gloves. Patience. Finish with 303 Aerospcae. Adds about 3 HP.
Old 11-18-2011, 03:56 AM   #5
Correct. (Not sure about the power gain...forgot to do a before and after dyno run.)
Old 11-18-2011, 05:34 AM   #6
Lacquer thinner is nasty stuff and will react badly with just about any plastic of vinyl it contacts.
+1 on the cover-up stickers. You have to look really closely to even see that they are there. The downside is that you only get a 1 or 2 hp gain with the stickers.
'99 black 986
Old 11-18-2011, 06:39 AM   #7
Chuck W.'s Avatar
I did the same thing, 9 years ago. They look great and no issues.
1995 Porsche C4 Cab
Old 11-18-2011, 07:00 AM   #8
J Tinsby's Avatar
Alcohol
Many thanks,
Ron
Used alcohol on mine and it did no damage at all to the vinyl. Lacquer thinner will make it soft and wrinkle it up... don't use it! May not be the fastest but it didn't take more than 10 minutes to get it done.
J T
"Never force it.... get a BIGGER hammer!"
J Tinsby is offline   Reply With Quote
Old 11-18-2011, 07:45 AM   #9
J T
Agreed...why cover up something unwanted when you can safely (and fairly easily) remove it? It's like putting a bandaid over an ugly mole!
Old 11-18-2011, 03:02 PM   #10
Autobahn Glanz
WhipE350's Avatar
I took the harsh nasty route, it was very clean when done but some what lighter then the black around it...no surprise there. Here's the thing though, I had black dye I had used on my seats and next used that. They now look like brand new, as if they never came with any sticker ever. I've had several people look at them and they say they look perfect.
Old 11-18-2011, 03:06 PM   #11
Are you making fun of my mole?
'99 black 986
Old 11-18-2011, 03:53 PM   #12
Only if it's an ugly mole...
Old 11-19-2011, 08:16 AM   #13
Worked great
The denatured alcohol worked great. Put it on a rag, rubbed it on, and in about 30 seconds it starts coming apart. About 3 minutes of rubbing later, and it's gone. No damage to either the visor or the vinyl.
Thanks guys!
