Old 11-06-2011, 05:40 AM   #1
Best sway bar kit for 01 S
Hello,
I'm researching sway bar kits & Have found the Eibach F&R to be a cost effective option.
The Eibach front is 24mm & the rear is 19mm. The stock S sway bar is 19mm?
Is it worth changing to the rear Eibach sway bar if it is the same size?
Are the Eibach stiffer?.
Also what drop link should I use?
Thanks Rich
RDS993 is offline   Reply With Quote
