Old 10-10-2011, 08:09 PM   #1
Brakes squeaking
Replaced all four pads recently, but I'm still getting some squeaking while coming to a stop. The squeaking is more noticeable after the brakes have been warmed up and been used for a little while.
Also, when I'm rolling back on an incline and I cover the brakes, the rear makes a louder more audible squeak/groan. This is pretty embarassing when parking lol. What can be the cause of this?
ASpec818 is offline   Reply With Quote
Old 10-10-2011, 08:48 PM   #2
Probably normal break-in for the new pads. Sometimes it can take up to several hundred miles before the squealing stops.
You can try removing the pads and using an anti-squeal spray or liquid on the back and edges of the pads to try to quiet them down. This may not improve things if the problem is the natural break-in of the pads but its cheap and easy.
Old 10-11-2011, 11:28 AM   #3
By the way, the loud squeaking sounds were there before the pads were replaced. Swapping out the pads did nothing about the loud squeaking/graoning noise when rolling backwards.
I originally thought my rear pads were done because of the noise but it turns out they didn't need to be replaced because they were still 85% or so. But since I had them out I just ended up swapping them out.
Old 10-11-2011, 11:52 AM   #4
jcb986's Avatar
You can use an anti-squeal spray by Wurth's on your Pad Vibration Damper or just replace them. I would bed my pads first...get to a good stretch of road, get up to a about 50mph and then stop hard without locking the brakes. Do that 3-4 times and then see if you have any problems. I would also suggest replacing the rotors if they have 60K or more on them.
Old Hippie Young Heart
Old 10-11-2011, 04:31 PM   #5
Bedding in the pads does help on the squealing. Also when I installed my Pagid's I chamfered the leading edge of the pad per the suggestion of the dealer. No noise what so ever going forward (sometimes a light squeal when backing up) and I did not use any anti-squeal goop.
Something to keep in mind.
2005 987 - 112K miles PASM + 6-speed - Daily Driver
1988 944 - 240K miles- Race Car
1974 911 Targa - new project
2009 Triumph Street Triple R - 27K mi - Blazen Orange
1976 Ford F250 camper special - tow vehicle
944boy is offline   Reply With Quote
