Old 09-27-2011, 09:12 PM   #1
mirror replacement question
Hi Guys,
I've searched and couldn't find an answer to this. I thought I'd asked the folks here before I dive into this project.
My driver side mirror suffered a stress crack, as as result I purchased an whole new (used) mirror and am ready to install it. My question is, do I need to remove the door card or can I just pop out the mirror control piece, and remove the 3 bolts, and reinstall the new mirror?
I've replaced mirrors on different cars before and some do require removal of the door cards.
Any help is greatly appreciative! Regards, Dan
DANMKII is offline   Reply With Quote
Old 09-28-2011, 07:02 AM   #2
no need to remove the door panel. be carefull w/ the 3 screws, though. it's easy to drop them down inside the door.
Originally Posted by DANMKII View Post
Hi Guys,
insite
'99 Boxster
3.4L Conversion
Old 09-28-2011, 07:41 AM   #3
Great, thanks!
Old 10-01-2011, 06:47 AM   #4
Okay, I ran into another snag. I removed the mirror switch and plastic triangle cover. My issue now is, I only see 2 torx screws and one is behind a very hard to reach spot.
What tool is needed to remove that third torx screw? Thanks!
Old 07-25-2014, 01:39 PM   #5
virgosunleomoon's Avatar
yeah, I have the same problem, what tool do you use to get in there?
virgosunleomoon is offline   Reply With Quote
Old 07-25-2014, 02:15 PM   #6
omg, you can just go right to it... there is a aluminum colored sticker over the hole....
I am so dumb...
