Old 09-18-2011, 10:01 AM   #1
DIY defrost cable
Hey all
Its starting to be colder already here in the morning. So this morning the glass windows of my top was frosted a little (Boxster 2000 S , not original top with a glass window). I put on the defrost and the mirrors defrosted but not the rear window. Took a look at it, and there is no wire from the window and nothing connected to the defrost plug.
So after looking on the net, I found a defrost harness for 160$ at Gahw top. Wow thats a lot for 2 wire and 3 connectors! I need to change the top in spring anyway and its comming with a wiring harness so I dont want to pay that right now and have it free with the top in spring.
Any DIY writing about a defrost harness?
wawa
wawa is offline   Reply With Quote
Old 09-18-2011, 10:39 AM   #2
You could always put a frost shield on the glass if it's just for one winter. That's if you can still buy them - haven't seen them for a few years, come to think of it.
'99 black 986
Old 01-14-2012, 02:09 PM   #3
Defrost harness
I picked up some 10 g wire and connectors at auto parts store today- looks easy enough. Will write back.
pauleyemd is offline   Reply With Quote
Old 01-14-2012, 04:56 PM   #4
bar10dah's Avatar
Yes, with wire gauges and connectors used, and I thought it was here on this forum, but a search for defroster didn't pop up the thread. I think the original poster said they built it for less than $10 and it worked real well. If I come across it again, I'll post it here.
bar10dah is offline   Reply With Quote
Old 01-17-2012, 11:31 AM   #5
If you search for hardtop install, the instructions should show where the rear window defrost wire outlet is located. The outlet is in all Boxsters and is under a small black plastic cover behind the driver's roll bar. It shouldn't be difficult to fabricate a small "jumper" wire to connect this outlet to your rear window defrost plug.
1997 Boxster
http://i40.tinypic.com/ax1qhz.jpg
Aron in Toronto is offline   Reply With Quote
Old 01-17-2012, 01:23 PM   #6
John99Boxster's Avatar
Search for my posting "Rear Defroster Help"
1999 Boxster
Ocean Blue Metallic/Savannah Beige | Tiptronic | Custom Rear Spoiler | 17" Turbo twist | Red Brembo Calipers | GAHH Top w/Glass Window | Tinted Windows | Cruise Control | Leather Interior | Heated Seats | Color Wheel Caps | Traction Control | Debadged
John99Boxster is offline   Reply With Quote
Old 01-17-2012, 01:26 PM   #7
Here it is....I thought I posted it here.....Its on Pelican.
Rear Defroster help - Pelican Parts Technical BBS
1999 Boxster
