09-04-2011, 07:37 AM
Finished headlight mods: HID + De-Amber + LED turn signals, city lights & fog lights
Sorry for the picture overload!
HID H7 low beam
Xenonmatch H7 high beam
H7 68 LED fog lights
5 LED city lights
De-amber + 20 LED amber turn signals
LED fog light
LED city light
Xenonmatch high beam bulb
09-04-2011, 07:38 AM
LED city light on, only
City light + HID low beam
City light + fog light
HID + Xenonmatch high beam
Low beam + high beam + fog light
09-04-2011, 07:39 AM
HID low beam + stock fog light
HID Low beam + LED fog light
De-amber
Halogen turn signal vs LED turn signal bulb
09-04-2011, 07:41 AM
Low beam + fog light + LED turn signal
De-ambered
Low beam + LED turn signal
Low beams
City lights and fog lights only
09-04-2011, 07:42 AM
Very jealous. I would give anything to rid my 02 S of it's awful amber yolk-ness. As of yet I have not been able to justify the cost of getting rid of it by replacing the assemblies. Someday....
2002 Boxster S Meridian\Boxster Red 6-spd
2006 Audi A3 2.0T Arctic White\Beige DSG
2010 BMW 535xiT Alpine White\Natural Brown
09-04-2011, 11:04 AM
Where did you find the LED fog and turn lights?
I would imagine they run a lot cooler than the OEM bulbs and won't melt or yellow the inside of the housing.
Wish I could say the same for the retrofit xenons in the low beams. I've heard that these sometimes damage the housings from the inside out. Hope that doesn't happen to your car.
I do love the look though. Are the LED's substantially brighter?
09-04-2011, 12:16 PM
I know what you mean, a pair of brand new assemblies can cost quite a bit, but those clear lenses do transform the look of the car. Sometimes just have to convince yourself harder.
09-04-2011, 12:21 PM
LED turn signals were from vleds, they are significantly brighter than stock halogens. I will post a comparison video shortly.
The fog leds were from ebay and they are not bright enough for my liking, I'm still searching for the right bulbs.
HID low beams actually run cooler than stock halogen as well, I have had them installed for over two years (one of the first mods I did) and they are perfectly fine.
09-08-2011, 11:51 AM
Just replaced the license plate lights as well, I'm impressed with the light output from the latest SMT LEDs!
Will snap some pics later.
09-10-2011, 11:01 AM
looking good, i like it!
11-15-2011, 02:08 PM
I hate to be a miserable old git, but I feel it won't be long before folk are re-ambering their pre facelift 986s. The car looks some much better with ze ambers. It is and always has been folly trying to make a car designed for ambers look newer with clear clusters. They nearly always look a lot better with the original ambers. But people usually don't realise this until the model is so ancient there's absolutely no point in trying to update it with clear lights.
12-23-2011, 06:03 PM
2006 987
I'm very interested in your headlight lenses, it looks like you cut the bottom of them?
My 2.5 came with burnt lenses, looks like someone might have put in bulbs that ran a little too hot.
Can I just cut the lenses out completely? The burnt plastic isn't horribly noticeable but it's annoying to me, like having a spaghetti stain on my shirt that only I know is there
12-23-2011, 06:21 PM
2006 987
here's a photo of the burnt lenses. Not horribly noticeable but it's annoying to me and at night it's probably blocking some of the light.
12-23-2011, 09:12 PM
I got a pair of 120 SMD LED's...BUT, they did not fit into the fog light housing by only a millimeter or two! I got these ones. . . . . . .
eBay Australia: Buy new & used fashion, electronics & home d
There are however, the same LED's on ebay, but in a width that's a bit smaller than the ones which I have posted, that SHOULD fit.
I have yet to attempt another order though.
12-23-2011, 09:57 PM
2006 987
so these LEDs you linked to will not fit our cars because they're too wide? How are they too wide? Can they be dremeled down?
12-24-2011, 12:07 PM
Correct. They did not fit by a millimeter or two.
I assume if you want to go through the hassle of trying to dremel it down, you can. But I'm sure it would be a bit easier just ordering a pair that is a tad less in width than the 2.0 cm.
There are ones with a width of 19mm that might have a better chance in squeezing in the housing. But like I said I have yet to try to order to see if they fit.
the 19mm one's might just do the trick though..
12-24-2011, 12:59 PM
My wife's car has the same problem, the previous owner put 70w bulbs in and melted the insides. I put 55w back in and I am planning to to a projector xenon upgrade which will not use the old burnt lenses.
2001 Boxster S 3.6L, Zeintop
12-24-2011, 03:12 PM
Maybe off topic. But I was told by a seller of SMD's that although they look white when you are looking directly at them they don't send out light the way a halogen bulb does. IE: They won't be as bright with the light they project onto the ground as opposed to an incandescent bulb. The color will be pure white but that's about it.
As to why this is so I really haven't been given a good explanation. Sure the smd's don't have a filament that radiates 360 degrees like a halogen, maybe that's the answer.
Of course Audi's R-8 has LED headlights so they must have found some way to make them work, how it was done I don't know. They say the low beams aren't good but the high beams are awesome.
J T
"Never force it.... get a BIGGER hammer!"
