Old 08-23-2011, 01:59 PM   #1
NEED help diagnose sound
i have a 2002 boxster 2.7 i have just went over 100k on miles and when i make a slow turn in left or right corner from stop i get a odd grinding clicking noise from the rear only if i get on it though if im slow and easy on the gas its fine but a sudden take off with any hard turn and click click click so as i staighten out its gone the car drives fine every other way i did have my brake pad light come on i know there due for maitenece any thoughts on the noise ?
wiznat81 is offline   Reply With Quote
Old 08-23-2011, 03:30 PM   #2
Keith Newby's Avatar
Sounds like a CV joint needing attention.
Keith Newby is offline   Reply With Quote
Old 08-23-2011, 04:49 PM   #3
ok cool now i ve looked up all the parts for that but am unsure if i buy a whole driveshaft assembly if it includes the bearing and cv joint? ill need left and right just as well do both while im in there.
Old 08-23-2011, 10:14 PM   #4
Includes the CV joint, but not the wheel bearing.
Sounds like the joint is bad, not the bearing. You should be fine with just the driveshaft assemblies. The castellated retaining nut should be replaced also.
http://i1215.photobucket.com/albums/...dall/Car-1.jpg
2001 S Speed Yellow, matching interior, German Plates!!
Iflylow is offline   Reply With Quote
Old 08-23-2011, 11:20 PM   #5
cool guys thanks for the info looks like a long weekend .
