Old 08-08-2011, 08:30 PM   #1
Water pump and motor mount with ramps?
Is it possible to change the water pump and engine mount with the car on ramps (about 7" high). I REALLY hate jack stands, and I had my rear end on ramps recently to swap mufflers in which i had PLENTY of room to fully maneuver and whatnot.
Thoughts?
stateofidleness is offline   Reply With Quote
Old 08-08-2011, 10:36 PM   #2
You can absolutely change the motor mount with ramps... that's how I did it.
1999 Carrera 4 • Aero kit • 4" UD Pulley
My Corvette doesn't leak oil... it sweats horsepower.
sd_boxster is offline   Reply With Quote
Old 08-08-2011, 10:45 PM   #3
Awesome! Thank you.
Old 08-09-2011, 06:28 AM   #4
Motor mount - no problem. The only problem I see with the water pump is getting something big enough to hold 5 gallons of coolant under the drain hole with only seven inches of clearance under the car.
I'm with you on the jack stands. I like having 17" of room under the car, but the lifting/lowering process is a pain with a real potential for disaster. I'm seriously considering a lift, probably a Max Jax Two Post Lift. Over the long term i think it will be well worth the money.
'99 black 986
