Old 07-16-2011, 05:28 AM   #1
101Projects or Service Manual on CD?
Which do you think is better? I'm going to fix my convertible top mechanism (broken cable, bent rod) but don't want to go into it blind.
peterbrown77 is offline   Reply With Quote
Old 07-16-2011, 09:19 AM   #2
101Projects has two good sections: one for replacing the top and one for repairing the top mechanism.
Old 07-16-2011, 09:37 AM   #3
+1 on Wayne's 101 projects book. Very good resource for the boxster enthusiast...
'13 S - Guards Red / Luxor Beige - Options - Loaded to the Hilt!!
'01 S - Guards Red / Beige - Surrendered - 04.18.12
jwade is offline   Reply With Quote
Old 07-16-2011, 11:27 AM   #4
You really should have both, but if you're only going to buy one then get the Bentley manual as sooner or later you will need the wiring diagrams. Also, everything in Wayne's book is avaialble online. I usually take my laptop out to the garage so i can pull up DIY's while i'm working on the car.
'99 black 986
Old 07-16-2011, 03:21 PM   #5
jcb986's Avatar
Absolutely both...Wayne's book is great on a lot of stuff that you can do for yourself.
Old Hippie Young Heart
jcb986 is offline   Reply With Quote
Old 07-17-2011, 06:24 AM   #6
I use both
Wayne's is awesome for the narrative and the pics, and the Bentley has the technical info, i.e., torque values.
http://i1215.photobucket.com/albums/...dall/Car-1.jpg
2001 S Speed Yellow, matching interior, German Plates!!
Iflylow is offline   Reply With Quote
Old 07-17-2011, 09:28 PM   #7
IMO. both are a must.........
jbs986 is offline   Reply With Quote
Old 07-18-2011, 05:10 AM   #8
I just noticed you said "service manual on CD" as opposed to theIbentley manual. I'll assume you mean the one readily available online or through ebay. I have that and it is usefull, contains different info than the Bentley manual. My revised answer about necessary manuals is:
Bentley manual
CD manual
OBD II manual
Wayne's book
parts catalog
links to sites like Pedro's, Pelican Parts, Mick Focke's and every other DIY page you can find.
In other words, get your hands on everything you can. it will all be useful at some point.
'99 black 986
Old 07-18-2011, 08:18 PM   #9
ChrisZang's Avatar
Depends on your experience level
Wayne's book is basically "Boxster Projects for Dummies" and it gave me the confidence of tackling projects that I never had dared to attack with the Bentley
So far I've done:
* deep sump install
* underdrive pulley install
* upgrade to 996 cluster (and such "hacks" aren't even mentioned anywhere else)
and very soon I will attack (as soon as the parts arrive):
* low temp thermostat
* water pump replacement
And from my point of view: Wayne's book is much closer to real life as the Bentley
