06-27-2011, 06:59 AM
			#1
				'99 Boxster Decelerates, Loses Power?
			1999 with 63,000 miles.  Car started to decelerate, acted like it was having trouble getting gas, would intermittently surge forward then decelerate.  I pulled over shut the car off, restarted
and the car drove fine.  No check engine lights.
I replaced the fuel filter.  Today, same problem.  Car starts to decelerate, I give it gas
but the engine is having trouble revving.  I stop and restart, the car runs better and I am able to return home, but doesn't run 100% smoothly.  Again, no check engine lights.
Does a fuel pump go bad intermittently?  I don't think it's bad gas.  Ideas?
Oil cap is not hard to remove when car is running.  Engine runs rough with oil cap off and smooths out when replaced.
Thanks.
Anyone, Anyone, Bueller....?
						Reason: Update.
			06-28-2011, 05:22 AM
			#2
			Wow, No one.
			06-28-2011, 05:35 AM
			#3
			certainly sounds like fuel starvation could be a cause.  Were you having the same issue before replacing fuel filter?  If not, might you have missed something upon reassembly or wrong filter or bad one at that?  The fuel sending unit/pump is located inside the gas tank but I think you need to confirm fuel filter is OK and do more diagnosis before digging in there.
So, confirm filter good and get the codes read... there might be some pending even though no warning lights.  Doing so will get you pointed in a solid direction so you don't have to spend money replacing parts experimentally.
Good luck
			06-28-2011, 05:56 AM
			#4
			Oil fouled plugs due to bad O-rings on plug tubes shorting out the sparkplugs?
This is another possibility.
Pull the plugs and see if the insulators are wet from oil.
Cheers!
PS FWIW, it's helpful to state the mileage on your car when seeking advice.
			06-28-2011, 06:04 AM
			#5
Cheers!
 63000 Miles.  Just changed the plugs at 62,000 and there wasn't any oil in there.  Fuel filter was changed after the first episode.  Thanks.
			06-28-2011, 08:10 AM
			#6
				I don't believe...
... in coincidences.
If you replaced the sparkplugs at 62K and now at 63K you have these issues, there has to be a connection.
One of your coils could be not connected properly (but the CEL would have indicated that).
Is your CEL working?
Did you remove/clean the MAF at that time?
Sure sounds like a MAF issue.
Happy Boxstering,
Pedro
				Racecar spelled backwards is: Racecar!
			06-28-2011, 08:21 AM
			#7
Happy Boxstering,
Pedro
Thanks.  I'm only assuming the CEL is working.  I have not cleaned the MAF, I will try that.  Thanks.
			06-28-2011, 08:37 AM
			#8
			I don't have CEL coming on... do I have to disconnect the battery to clean the MAF sensor?  Also, is there a certain mileage that it should just be replaced?  thanks
						Reason: addtion
			06-28-2011, 09:15 AM
			#9
			you dont have to disconnect the battery, just pull the maf. easy way is just to unplug the MAF and drive.  if the problem is still there, then it is not the MAF.
Does not hurt to clean it though.  you will need tamper proof torx heads.
				2002 S
			06-28-2011, 10:20 AM
			#10
			I just had similar problem with my 2001.  It would usually run fine, but sometimes I would feel it lose power.  When I stepped on gas pedal, no response.  sometimes it would die and wouldnt start for a while.  No cel lights ever came on, porsche repair shop dumbfounded.  Finally died and had towed immediately.  Turned out it was the fuel pump.  Had it replaced and good ever since.
				Richard Griffin
Atlanta GA
2001 blk/tan Boxster  18" turbo twist wheels
2003 gray/tan Navigator
			06-28-2011, 10:37 AM
			#11
Interesting, I will look into that next.  I thought it might be my fuel pump, but never had one work intermittently before.  Thanks.
			06-28-2011, 05:58 PM
			#12
			When my fuel pump failed the car had the same symptoms just as you described. It had loss of power when trying to accelerate and then surge spastically. I had to slow down to maintain a drivable condition then I was able to get to my destination (repair shop) before it completely died and wouldn’t start. I'm glad to say it didn't leave me stranded.
				Jäger
300K Mile Club
			06-29-2011, 06:06 AM
			#13
Thanks.  Yep that's sounds like mine.  I cleaned the MAF (which didn't seem dirty at all) and the car drove fine after that.  But my problem has been intermittent, and since the
CEL didn't come on it makes my think it could still be the fuel pump.
			06-29-2011, 08:15 AM
			#14
				since CEL didn't come on it makes my think it could still be the fuel pump.
Test to see if the CEL works.  It may be burnt and you could have a bunch of codes.
Switch the ignition on (without starting the car) and see if the CEL lights up.
If it doesn't it may be out.
Happy Boxstering,
Pedro
			06-29-2011, 12:41 PM
			#15
Happy Boxstering,
Pedro
Thanks!
It actually does come on with the other lights.  Will there be codes there even if the CEL isn't on?    Does it sound like a flakey fuel pump if the CEL isn't coming on?
			03-05-2014, 06:30 PM
			#16
			 2006 987
				Thanks!
Was this resolved?  I'm having a very similar issue with a 987.
I will shift (downshift or upshift, doesn't matter), and once in the new gear the car acts like the gas pedal isn't even connected.  Like tonight at a green light I had it in first and it started moving then it acted like the gas pedal wasn't even connected, so I shifted to 2nd and it acted normal again.  Seems shifting fixes it, but I don't want to always have to shift, it should have power in the gear I'm in.  Happened in 5th too, I even floored it and pumped the peddle, just acted like the gas pedal was connected to nothing but I could hear the peddle hit the floor, but as soon as I shifted to 4th it behaved normal again.
				2006 987 2.7 manual silver/black, PASM, OEM drilled rotors, heated seats
1998 986 2.5 manual black/tan with bad engine = SOLD
			03-06-2014, 12:13 PM
			#17
			 2006 987
			Porsche shop was finally able to reproduce the issue.  They're saying it could be pedal sensor?  Diagnostic computer did not detect anything when vehicle lost acceleration.  Sensor is never suppose to fail so no dealers in area have on hand, will take a week to get one and installed.
I'll update if that solves the problem, I'm just glad they were finally able to reproduce the issue themselves because there is nothing worse than bringing a car to a shop and they say that they don't see anything wrong.
			03-06-2014, 12:18 PM
			#18
			Intermittent problems are the worst. They always disappear the moment the mechanic gets behind the wheel.
				'99 black 986
			03-06-2014, 01:00 PM
			#19
			 2006 987
Completely agree.
Most people curse that check engine light coming on but they have no idea how much worse it is when something happens and a light does not come on.
