Old 05-18-2011, 07:35 AM   #1
Here's what I found in blown engine number 2....
metal shavings the size of a dime. Looks as though someone with a wood plane has been inside the engine?!? This was stuck to the handy magnetic drain plug that I got from LN. Any guesses as to the cause/source of the filings and shavings?
Byron in Atlanta
Byron in Atlanta is offline   Reply With Quote
Old 05-18-2011, 09:27 AM   #2
BYprodriver's Avatar
most likely spun rod bearing
Old 05-19-2011, 12:42 AM   #3
Steve Tinker's Avatar
It would have to be magnetic - which rules out (most) of the alloy or white metal componants in the engine.....
Conrods, crankshaft, IMS bearing / shaft, timing chains / sprockets, oil pump gears / drives etc, etc.
Looks terminal whatever it is !!
2001 MV Agusta F4.
Old 05-19-2011, 06:11 AM   #4
Track rat
Topless's Avatar
Shredded IMS bearing?
Old 05-19-2011, 09:42 AM   #5
Engine Surgeon
Yep.. Looks like it lost a rod bearing to me, they are steel backed and shed material shaped like this when they fail.
US Patent 8,992,089 &
US Patent 9,416,697
Old 05-24-2011, 10:33 AM   #6
Wow! Any clue how or why that happened?
What track were you at BTW?
Mike_Yi is offline   Reply With Quote
Old 05-24-2011, 10:41 AM   #7
My guess would be a rod bearing as well.
Boxster S
