Old 04-29-2011, 08:30 AM   #1
Wheel Offset expalined?
Could somebody expain what exactly is wheel offset, and where it is measured from?
surf40 is offline   Reply With Quote
Old 04-29-2011, 08:46 AM   #2
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=101
Demick
'04 Boxster S
demick is offline   Reply With Quote
Old 04-29-2011, 08:59 AM   #3
DFW02S's Avatar
The distance between the mounting surface on the hub and the center of the wheel.
When you add a spacer the offset/et is reduced by the spacer size because you're moving the center of the wheel closer to the mounting surface on the hub.
I actually struggled for a bit with understanding offset. Now I has it undr control.
DFW02S is offline   Reply With Quote
