Old 04-13-2011, 02:50 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
What do you use to clean a BMC air filter?
Should I purchase the actual BMC filter cleaner or can I use the k&n cleaning kit?
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 04-13-2011, 03:25 PM   #2
you can use either.
The biggest issue is with re-oiling it (K&N oil is fine). However, less is more and make sure you let it sit on newspaper for a day or two to soak up all the excess oil and then some. Otherwise, you'll eff-up your MAF. Then costs saved from not buying a new air filter will be quickly evaporated by spending 3-4x on a new MAF... You can usually find BMC air filters on ebay pretty cheap FWIW.
