Old 04-03-2011, 12:54 PM   #1
One touch windows - new member
should both windows be one touch up and down? my drivers (rhd uk car) works fine and my passanger window one touches down but not up? any help to make passanger one touch to go up? thanks
munroe13 is offline   Reply With Quote
Old 04-03-2011, 01:41 PM   #2
schnellman's Avatar
Both For Me
On my 986 they are both one touch.
Old 04-03-2011, 02:48 PM   #3
Guvs's Avatar
Hi.
Mine are one touch up and down on both windows, Mine is a RHD 03 face lift 2.7
Guvs.
Guvs is offline   Reply With Quote
Old 04-03-2011, 06:16 PM   #4
I have subscribed to this - I have the same problem. Drivers works both up and down, passenger only works going down..... Interesting!
Sam
sparker is offline   Reply With Quote
Old 04-04-2011, 09:40 PM   #5
My car ('99 LHD) works on both windows, up and down. The guy I bought the car from is a dealership Porsche mechanic, and he gave me a tip on resetting the automatic windows:
He said if they were not working or only going partway up, all you had to do was put the window up all the way, release the window up button, then press the window up button one more time. Conversely, put the window all the way down, release the window down button, then press the window down button one more time.
I have no idea if this will solve your issue, but it only takes a few seconds to try!
Tieniber is offline   Reply With Quote
Old 04-05-2011, 05:36 PM   #6
Couper1's Avatar
The window regulator may have a bind in it causing the problem.
I know that when I disconnect the battery for some time, I have to "reset" the windows to work automatically up and down again.
If you just put it down, then up then down again it should fine the parameters and reset itself.
Couper1 is offline   Reply With Quote
