Old 03-02-2011, 01:59 PM   #1
Question for the wheel experts...
would the following fit a boxster without issues
19x8.5 (offset 45-47)
19x10 (offset 56)
thanks.
mikes_box is offline   Reply With Quote
Old 03-02-2011, 03:06 PM   #2
Johnny Danger's Avatar
19x10 (offset 56)
thanks.
The fronts are fine. However, +56 is an extremely high offset for a 10 inch wheel on a 986 boxster. Depending on your suspension set-up, you'll have to use spacers. 10mm's is probably a good start .
Old 03-02-2011, 05:23 PM   #3
BYprodriver's Avatar
My OEM 996 Carrera II wheels with 65 offset fit with 1" spacer & 265/35/18 tire. 285/30/18 tire rub the outer wheel wheel & my 2000 S is at max OEM ride height
