Old 05-27-2005, 02:24 PM   #1
glass window tops
Hi ,
this my first post to the group.
I just finished the instalation of an aftermarket top with a heated glass back window. fit is perfect, defroster grids are small and black.
Total time to install was less than 5 hours and no alterations to frame.
top folds just right, but there is slightly less room in the service postion.
I took extra care to clean and lube all pivot points and seals.
I still need to work up a wire harness to hook up the defroster.
FYI: I work in the automotive repair field so my labor times are accurate as is my assesment of the opperation of the top. The window is smaller by 5 inches in height and about 4 inches narrower across the width. but visability from the seat is as good as before, maybe better without the distortion even new plastic has.
the top was made by a southern California company.
mgjim55 is offline   Reply With Quote
Old 05-27-2005, 02:25 PM   #2
glass window tops
forgot to say that my car is a 1998 Boxster.
Old 05-27-2005, 06:46 PM   #3
Where'd you buy the top and how much did it cost?
There's at least three other threads on glass window replacement tops but this is good info.
Old 05-28-2005, 03:33 PM   #4
yeah, how much was it and would consider installing on my 2000 box for a fee? i will help of course, i am not that bad of a handy man but i dont wanna mess it up. i am in south bay area, near Torrance, CA. let me know and thanks.
kajita is offline   Reply With Quote
Old 06-13-2005, 10:16 PM   #5
Alshig's Avatar
top
Was the top from GAHH?
Psychobox
Alshig is offline   Reply With Quote
Old 06-13-2005, 11:14 PM   #6
Originally Posted by mgjim55
I took extra care to clean and lube all pivot points and seals. company.
Any pctures?
