Old 02-05-2011, 12:23 AM   #1
i doubt anyone can help me on this 1
My radio resets every time i turn the car off. I cant make presets or anything because of this. It's a Pioneer if that helps
DerrickCaracter is offline   Reply With Quote
Old 02-05-2011, 03:48 AM   #2
Rennzenn
j.fro's Avatar
Along with the main power wire, there is an auxiliary/memory power wire. This needs to be connected with something that keeps power, even with the ignition off.
Old 02-05-2011, 08:07 AM   #3
Yep. Usually yellow, IIRC.
98 Arena Red 986
Stroked & Blown is offline   Reply With Quote
Old 02-06-2011, 03:19 PM   #4
Same thing happened to me when I installed my Clarion unit. I used an install kit I got from Crutchfield and the wiring connector had the main and memory power pins swapped. I just swapped them in the connector and all was good.
VBoxster is offline   Reply With Quote
Old 02-06-2011, 10:42 PM   #5
you probably switched the constant 12v with the switched 12volt.... switch em around and you'll be fine...
mikes_box is offline   Reply With Quote
