Old 01-21-2011, 04:53 PM   #1
Radio Wiring 03
New O3 2me... Have Unusual Wiring..on B & C
Bottom Bus Has Typ. "kramer A" Connector To Facilitate Power/ground/needs
Middle Bus Has Typ "kramer B" Connector To Normally Facilitate Speaker System R/l F/b-----no Wiring Available
Top Bus Has Typ "kramer C" Connector To Facl. Amp?? In My Case It Has A Yellow Connector With Mulit Wiring (6 CONTACTS ONLY)???
Can Anyone Explain That Top Bus?
Additionally Is There A "master Fuse On The Drivers Sidewall Fuse Panal That Controls The Power (besides The 10amp @ Radio)?
Pics Attached
WRGREENER is offline   Reply With Quote
Old 01-22-2011, 05:45 AM   #2
Yes, there is a separate fuse in the fuse panel for the audio system.
From '03+, Porsche used the MOST (fiber optic) loop system daisy chaining the head unit, amp, and any accessories (NAV, CD changer, etc) together. Thus, there aren't any traditional line level outputs or amplified outputs from the rear of the head unit.
See this thread for more help/info...
renntech.org/forums/index.php/topic/25829-becker-cdr-23-pinout-or-connector-wiring-diagram/
Congrats on your new to you Boxster
Old 01-22-2011, 06:14 PM   #3
Most
OK, PLEASE BEAR IN MIND THAT WHEN I BOUGHT THE CAR THE PREVIOUS OWNER STRIPPED OUT THE SPARE/TOOLS/MANUALS/POSSIBLY THE CD CHANGER.
CAN YOU TELL ME THE FUSE NOMENCLATURE I NEED TO INVESTIGATE (e.g. A-9,E-1) FOR A BAD FUSE. IS THE MOST SYSTEM SOMETHING THAT NEEDS PROGRAMMING OR TWEAKING AFTER TRAUMA (LIKE WATER INFILTRATION AND REPLACEMENT OF COMPUTER SYSTEM UNDER DRIVERS SEAT OR BATT. DISCONNECT OR OTHER)?
IF THE CD CHANGER WAS TAKEN, DO I NEED IT FOR THE MOST TO WORK=RADIO TO WORK. DOES THE MOST CONTROL THE SPEAKER SYSTEM,ALSO?
Old 01-23-2011, 05:38 AM   #4
CD Changers are an option so don't be so sure yours should have it. If it does/did, it'll be in the front trunk. If it's missing you'll at least need a MOST loop connector to close the system and it may need reset w/ the Porsche PIWIS system to take it out of the loop.
Contributing members at Renntech.org can download a users manual. In the mean time, here's a link to a fuse panel diagram from Mike Focke's '01S from his google Boxster page (basically same for most 986 Boxsters):
Cut & paste this link:
156972798683730054-a-1802744773732722657-s-sites.googlegroups.com/site/mikefocke2/fuzebox01S.jpg
Good luck
Old 01-23-2011, 07:51 AM   #5
no loop @ in front bonnet, found renn list info, and following the link. thanks
