Old 01-17-2011, 11:20 AM   #1
jaykay's Avatar
O/D of instrument cluster gauges
My 00 S is storage and cant be accessed. I need to know the outside bezel diameter(s) of the three main gauges! Yes I am making something
986 00S
Old 01-17-2011, 11:34 AM   #2
I'll take my digital vernier home and measure them tonight
I should post the numbers u need sometime after 7 pm MST
Unless someone beats me to it
cheers
chris
Living one calculated risk @ a time
chris97boxster is offline   Reply With Quote
Old 01-17-2011, 06:01 PM   #3
jaykay's Avatar
Awesome most wonderful of you
986 00S
Old 01-17-2011, 06:09 PM   #4
not easy
I measured the OD(outer dia.) And got 4.520 inches (measuring horizontally)
the ID (inner dia ) was 4.000
but...
the bezels r not perfectly round.....elliptical
I couldn't measure the outer bezels
the pod cover gets in the way and so does the steering column
I was using my 6 inch digital verniers hoping they would fit
well they do...but the tips need to be thinner
I don't think a micrometer (4 to 5 ) would have the necessary room either
but back to the original issue I c...they r elliptical which means to get a proper
measurement ...it would be nice to get to whole cluster out
this doen't help u right now
try a paper cutout when u get a chance
if I had access to an instrument pod. .I could probe it on the machine @ work
but it would b so much easier if some1 had the drawing of the whole cluster (dwg/iges)
cheers
chris
Old 01-17-2011, 07:23 PM   #5
jaykay's Avatar
Chris thanks very much .....this is a great help
Eliptical is problem for me and will do as you say.....so it is hold until can get in the car
986 00S
