Old 12-03-2010, 04:31 AM   #1
Raising Passenger Seat
I am trying to mount an amp underneath the passenger seat in my '01S. In order to retain full fore/aft range, I need to raise the seat by 1/2"-3/4".
Any problems with placing spacers underneath the mounting rails?
Alternatively, as it is I lose about 6" of aft travel. I can live with that, but is there any kind of adjustable stop on the electric seat control? If I can limit the travel and avoid damaging seat/amp, I'm OK with that, too.
http://i1215.photobucket.com/albums/...dall/Car-1.jpg
2001 S Speed Yellow, matching interior, German Plates!!
Iflylow is offline   Reply With Quote
Old 12-03-2010, 04:38 AM   #2
just make sure the longer bolts are of the same hardness
extanker is offline   Reply With Quote
Old 12-03-2010, 04:40 AM   #3
Good point, hadn't thought of that.
Old 12-03-2010, 04:49 AM   #4
in an accident weaker bolts could make it into a james bond ejection seat
Old 12-03-2010, 04:56 AM   #5
JTP
This might be an obvious question but did you try raising the seat using the height adjustment? Or was that not enough to clear?
JTP is offline   Reply With Quote
Old 12-03-2010, 11:57 AM   #6
Have you driven the car with the seat raised. I am only 5' 6" and I can't stand to have the seat anywhere but the lowest position. Any higher and it feels like I am sitting on the car instead of in it.
2000 New Beetle / in search of 03 986S triple black
Caractere kit seam sealed, Caractere rear wing, 1 3/4" drop on coilovers, 235/40/18 Kuhmo XS on 18x8 Millie Miglia Spider II's, H2sport spindles, H&R front Sway bar, O-bar rear torsion, VF Eng. motor mounts, G60 12# flywheel, Nuespeed P-flow intake, Forge DV, Samco IP, Custom K04 turbo and Upsolute chip, 4 bar fpr, TT 2 1/2" SS DP, 2 1/2" custom stainless exhaust no muffler, Peleguin LSD, B&M SS, Momo 14" wheel, R32 steering rack.
yelojkt is offline   Reply With Quote
Old 12-03-2010, 10:29 PM   #7
I wouldn't raise the driver's seat. This is under the passenger seat. Until I can get some longer, hardened bolts, I will have to make sure my passengers just don't mess with the seat adjustment
BTW, the German version of Pep Boys doesn't sell hardware
Old 12-04-2010, 06:07 AM   #8
take an old bolt and go to your dealer and ask for 4 bolts like this but 1/2 inch longer,they might give ya them for free
Old 12-05-2010, 11:42 AM   #9
Thanks. Ill try that. I raised the seat by 3/8" just with some washers. I know it may affect the safety, but it is temporary and I don't have passengers very often.
