Old 11-29-2010, 05:34 AM   #1
wet drivers footwell
anyone any ideas as to what could cause a wet foorwell on the drivers side of a 1997 boxster ? any help / advice would be much appreciated.
508421 is offline   Reply With Quote
Old 11-29-2010, 06:06 AM   #2
JTP
http://986forum.com/forums/showthread.php?t=22781&highlight=Wet+door+panel
JTP is offline   Reply With Quote
Old 11-29-2010, 12:19 PM   #3
Beelzy's Avatar
Roof Leak!!!
Check under the driver's seat and make sure the Alarm box hasn't gotten wet.
I would hose the car down and see where the top is leaking ASAP.
Beelzy is offline   Reply With Quote
Old 11-29-2010, 07:18 PM   #4
Depending on the location of the wetness, it could be coming from a few different sources:
1. Overflowing/clogged drains in the front trunk, to the rear of each side of the battery tray;
2. Torn, missing or unglued plastic foam liner under the door panel;
3. Leaking heater core.
4. Convertible top drains in the convertible top well, if water has migrated to the footwell after entering from the rear of the cabin.
5. Sometimes there is a small space at the lower corner of the front left firewall that can let in water.
If it is from the heater core, the liquid will feel a little viscous.
Regards, Maurice.
schoir is offline   Reply With Quote
Old 11-30-2010, 05:56 PM   #5
The bottom line: check the carpeting along the bottom edge of the door. If this is wet, then you have water leaking past the plastic foam liner inside the door, which is soaking the door carpeting, which is then dripping into the footwell.
Rich F
somewhere
past: 2000 Boxster S
past: 2010 Boxster S
turbo23dog is offline   Reply With Quote
Old 01-11-2011, 08:08 PM   #6
HI and thanks for your comments / help , the problem does not seem to be coming from the door as the carpet below the door is bone dry , the moisture is only present around the area where the pedals are and is working its way toward the seat , i keep it as dry as possible to protect the electronics below the seat , maybe it stems from drainage ?? any further help / advice / instruction would be great , cheers.
Old 01-11-2011, 09:56 PM   #7
Take a look at the following link for diagrams/locations of the drains in the front trunk for a possible cause to the water intrusion that you describe: http://sites.google.com/site/mikefocke2/drainsdiagram
The other possibility, as I mentioned in the earlier post below is that the water is leaking from the radiator core.
Regards, Maurice.
