Old 10-28-2010, 01:13 PM   #1
Brake fade idiot light is on .. have a few questions
I've been driving around for a little while with the light coming on and turning back off. Now its just on permanently and there's lots of squealing so its time to bite the bullet and get the brakes done.
I called my local mechanic and the quote was $480 for labor both front and rear. Is this normal ? I trust the work of this shop but I was expecting a lower price for a simple brake job.
He also said he always change both pad and rotors at the same time for any brake job and this didn't sound right to me either. Is it actually something special about the Porsche brake design that requires this ? I think my rotors are still OK but I'm not 100% sure. Steering wheel shakes a bit during heavy heavy braking but nothing too violent.
As far as pad / rotor choices, I am going with Hawk HPS and Bola rotors ( if I need them ). I have never tracked ( although want to ) but I do drive pretty aggressively on the mountains near my house. Is this a good pad / rotor choice ?
vijen6 is offline   Reply With Quote
Old 10-28-2010, 01:54 PM   #2
Pat
You don't have to change rotors and pads at the same time. Nothing special about your brakes vs. others.
Those rotors and pads are good enough for what you do.
Labor is reasonable.
Steering wheel shouldn't shake. Likely pad deposit. Possibly warped rotor. If warped, you have to replace. If pad deposit, could rebed the pads and it may just go away.
-Chuck Patterson
Old 10-28-2010, 02:00 PM   #3
Considering that new Porsche pads will run you about $300 ($164 for non-geniune), and rotors will cost you roughly $650 ($300 for non-genuine), the price isn't bad. It's an easy job though, so it doesn't require much labor (maybe 2 hours).
If you get Hawk HPS, be aware that these will eat your rotors very quickly, and will generate tons of brake dust. Clean your wheels regularly (weekly maybe) and keep them polished/waxed. Personally, I'd recommend sticking with regular pads for day-to-day driving, and swap out the Hawks for the track. It's an easy job and doesn't take long. In fact, it will probably take longer to jack the car, remove and re-install the wheels than it will to change the pads.
Mike_Yi is offline   Reply With Quote
Old 10-28-2010, 02:03 PM   #4
Pat
Hawk HPS are not suitable for use on a race track.
I've used a few pads that dust more than the HPS and am alright with it. If you want stopping power, you're going to deal with dust.
-Chuck Patterson
Old 10-28-2010, 02:57 PM   #5
Talking
The reason I'm going with HPS is because I can get them both from + back from R1Concepts for $260 total which is a great deal I think and I've heard good things about them from other members.
Another possibility is the Porsche Sport pad set which is supposed to be slightly more aggressive than stock but less aggressive dusty than aftermarket ( http://www.****************************************************.com/product/99635198000AND99635298000.html?Category_Code=986bo xsters ) for about the same price.
My mechanic recommends Pagid and Textar which I also see good comments from on the site.
A little confused by all the choice to be honest, but I think HPS is a good bet. A little dust will give me an excuse to wash the car more often.
nefarious986 is offline   Reply With Quote
Old 10-28-2010, 04:26 PM   #6
jcb986's Avatar
Did all 4 of mine foe about $300 bucks...parts from Pelican. All 4 new rotors made by Balo from Germany. Used Mintex Red Box Pads and I also flushed the brakes. Very happy with them and they feel a lot better than the originals than where on the car.
Old Hippie Young Heart
Old 10-28-2010, 09:53 PM   #7
Regardless of pad and disk choices you make, spend just a tad more money and get stainless brake lines while you're at it. Even cheap eBay ones make a HUGE difference in braking. Talk about a firm pedal! It's like night and day.
