Old 10-22-2010, 08:16 PM   #1
High Watt High Beams
Has anyone used 100 watt H7's? Any problems? Will the factory wiring take it? Will the lenses and housing take it? If they're too hot, what bulb is available? I'm using Sylvania Silver Stars and I like them but would like more light w/o the cost of litronics and headache of aftermarket HID. Thanks,
"Now the company of rogues & cutthroats is complete."
2002 Boxster S
1993 Range Rover County LWB 259k miles
1995 Infiniti J30 - 24 Hours of LeMons
ray96disco is offline   Reply With Quote
Old 10-23-2010, 04:08 AM   #2
High watts bulbs burn the lenses
as many have found. Bigger is not better. Bigger is very costly.
Sylvania advertises: "H7SU SilverStar Ultra: The brightest and whitest light. Up to 50% brighter, up to 40% more downroad visibility and up to 50% more sideroad visibility."
Note the "Ultra" and the "H7SU"
Old 10-23-2010, 06:15 AM   #3
bulbs
I would be very concerned about putting a higher wattage bulb in, as these headlight housings allready have a know problem with burn marks
brian325is is offline   Reply With Quote
Old 10-23-2010, 06:47 AM   #4
Auf los!'s Avatar
I think you are going to find that 100-watt bulbs of ANY designation are very short-lived, and not worth it, especially when you consider that changing bulbs on a Boxster is not a 3-minute job.
You should consider the Osram 65-watt H7s sold by candlepowerinc.com. They are H9 bulbs on an H7 base. I recently installed them in my wife's non-HID Passat, and they really made a difference. The OEM bulbs were absolutely pitiful.
I haven't installed these Osrams in my Boxster because I have the factory HID, and I hardly ever use the foglamps or high-beams...the factory HIDs are THAT good!
Auf los! is offline   Reply With Quote
Old 10-23-2010, 07:36 PM   #5
Thanks for the information. I'll stay away from the high watt bulbs.
2002 Boxster S
