Old 08-03-2010, 12:26 PM   #1
2001 RUF 3800S
violametallic-S-'s Avatar
RSS under pulley: can I reuse the crank pulley bolt?
I've been postponing this install due to lazyness. Now it's time. I called rss to see If I could reuse my crank pulley bolt and I didn't really get a confident answer but he said for my year yes I can reuse it. Just wanted to know if anyone has reused it before without issues?
IG: RUF3800S
violametallic-S- is offline   Reply With Quote
Old 08-03-2010, 12:30 PM   #2
There was a writeup on here very recently covering this.
IIRC, they are not reusable. The bolt stretches when torqued to spec, similar to many head bolts.
98 Arena Red 986
Stroked & Blown is online now   Reply With Quote
Old 08-03-2010, 01:08 PM   #3
Carnut
AndyA6's Avatar
How about the belt, then? I guess that has to be changed as well, right?
Old 08-03-2010, 01:53 PM   #4
I have the RSS underpulley, I used the exact same bolt, I have driven the car in a very spirited fashion without any problem, as for the belt, it's a different size, replace the bearings in the rollers too, they are cheap at napa.
Old 08-03-2010, 03:30 PM   #5
bolt replace
I reused my original bolt, no problems so far... that bolt looks like it belongs in a tank, how does it stretch?
01 boxster black/tan- FVD exhaust and ECU tweak, K & N air filter,
de snorked, underpulley, carbon fiber rear wing, H & R lowering springs, lemans rims by victor equipment
lbrown2009 is offline   Reply With Quote
Old 08-03-2010, 09:47 PM   #6
2001 RUF 3800S
I called Porsche and the part is like only 4 dollars so ill just switch it just incase. But I thought with the RSS UP you can reuse the same belt?
IG: RUF3800S
Old 08-04-2010, 03:08 AM   #7
[QUOTE=lbrown2009]I reused my original bolt, no problems so far... that bolt looks like it belongs in a tank, how does it stretch?[/QUO
Eggactly, I would only add mine was pristine, zero corrosion or thread corruption.
If anyone wants the roller bearing numbers or the gates belt number message me, I have both in my car log.
Old 08-14-2010, 11:29 AM   #8
2001 RUF 3800S
anyone reuse the same belt? I wasnt told that you need a belt.
IG: RUF3800S
Old 08-14-2010, 12:24 PM   #9
I have the 4" pulley, and replaced the belt with a shorter one, although I believe on your RSS pulley (which is slightly larger), that many have used the stock belt, and the belt tensioner should take care of the slack just fine.
http://farm4.static.flickr.com/3420/...90927559_o.jpg
Some stuff for sale: M030 S 24mm front sway bar, M030 base 19.6mm rear sway bar, 996 GT3 OEM Porsche Motorsport front strut mounts monoball "camber plates"
WTB: looking for some 5-7mm spacers with extended bolts
chaudanova is offline   Reply With Quote
Old 08-14-2010, 12:32 PM   #10
In a word, NO wont work. Gates belt for use with RSS pulley from my work notes
belt is 060827
Old 08-14-2010, 01:47 PM   #11
Johnny Danger's Avatar
In past I've read articles, wherein boxster and cayman owners claimed to have used the original belt. How they were able to accomplish that is beyond my understanding. When I installed my new under drive pulley, albeit BBI's product, I discovered that the oem belt was clearly too long .
Old 08-14-2010, 05:34 PM   #12
2001 RUF 3800S
belt is 060827
Where can I get the belt and bearing? I googled the belt part number and found a site but it says its for mercury cougars...
IG: RUF3800S
Old 08-14-2010, 07:38 PM   #13
You can get the bearings and the belts right at NAPA, trust me, I made extra round trips due to the same information, do what makes you happy or take my advise and get:
skf bearings 6203-2rsj (same for tensioner & roller, best quality available at napa) and the gates belt number I gave you. You will need a bearing punch or similar drift to drive out the old bearings.
